No solution from simulation
Old   December 12, 2020, 17:51
Default No solution from simulation
Sara
Knowledge is on a distinguished road
Hi everyone
The solver manager succesfully completed but when I go inside the CFD-post nothing is there; no time or anything. What could be the reason?
I decided to only look at temperature, velocity and pressure which I specified inside output control --> results. Could it be the cause?
Knowledge is offline   Reply With Quote
Old   December 13, 2020, 02:39
Did you actually save anything into your results file?
In CFX-Pre I would return the output tab to default settings and run again. That should at least give you a final condition result. And if transient add a few intermediate results as well.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 13, 2020, 16:15
Sara
I solved the problem. I just decided to go with the standard variables.
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 18:28
Unsteady simulation solution files in parallel gunnersnroses SU2 1 December 15, 2015 13:28
How can I use solution from one simulation as initial condition on a remote solver? Dano62 CFX 0 October 21, 2015 17:45
Save Solution Data in a Fluent Transient Simulation asf_card FLUENT 3 September 15, 2015 21:41
Unsteady simulation with steady solution as initial value kiddmax OpenFOAM Running, Solving & CFD 8 August 20, 2015 05:12
