CFD (CFX) for airfoil pitching moment calculation |
December 12, 2020, 20:25 |
Rep Power: 5 |
Supposing the structured mesh is enough fine, convergence goes to residual = 10^-5, turbulence modeling SST, is CFD (using CFX) accurate (less than 5% error) for conventional airfoil pitching moment (Cm) estimation? |
December 13, 2020, 02:35 |
Rep Power: 143 |
That depends on what you want to do with it.
If you are just testing a few concept designs then high accuracy is not required. If you are trying to work out why a specific failure mode occurs at some precise condition then high accuracy is required. If you are a jet engine design and you intend to improve the efficiency of your engine by 1%, then extreme accuracy is required.
December 13, 2020, 03:37 |
#3 | |
Rep Power: 5 |
I'm doing CFD modeling for an aircraft wing, but I see CFD's prediction on pitching moment Cm is more 20% larger than the wind tunnel test data. So I'm trying to figure out whether it is typical to have result like this (that means CFD not accurate for pitching moment calculation) or I made an error somewhere. |
December 13, 2020, 05:10 |
Rep Power: 143 |
I am not a specialist in airfoil modelling, but I know getting the lift accurate is much easier than the drag. Many researchers get the lift accurate to within a few percent, but getting drag accurate to within a few percent is very challenging. I cannot say for pitching moment as I have no experience for that one.
Convergence issue- ANSYS CFX - Ceiling Fan CFD analysis | Deepaksha | CFX | 16 | July 9, 2020 15:36 |
CFX vs CFD for multiphase+particle | zeitoun | Main CFD Forum | 1 | June 5, 2010 21:35 |
Ansys CFX vs CFD for multiphase+particle | zeitoun | ANSYS | 1 | June 4, 2010 03:58 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
CFX /Fluent as CFD modeler | Carlos | CFX | 5 | February 2, 2005 16:32 |
