Unstructured-meshing for Unshrouded-Impeller
Old   November 5, 2006, 08:35
Default Unstructured-meshing for Unshrouded-Impeller
Turbomachinery
Dear Friends,
I'd like to adopt the unstructured-mesh (using ICEM CFD tetra + prism) to unshrouded-impellers, i.e. there exists a gap between the blade-tip and the wall.
If the unstructured grid system based on tetra and prism, without hexahedral-meshing, should be applied, do the prism-layers have to be made on both the blade-tip and the shroud-wall to improve the boundary-layer resolution or on the shroud-wall only (and the tetra meshes on the blade-tip)....due to the narrow tip-clearance_^^.
I look forward to your constructive advice on it.
Thank you very much in advance...
Old   November 5, 2006, 15:23
Default Re: Unstructured-meshing for Unshrouded-Impeller
It is generally best to have full inflation/prism layers, but you may be able to use a tet mesh only right at the blade end. You will have to try it on your geometry and establish for yourself whether it is sufficient.
Old   November 5, 2006, 17:28
Turbomachinery
Thank you for relying to my query....
There is a tip-clearance (relatively small-gap comparing with other geometric dimension, e.g. diameter) and we are going to construct the 'tetra+prism' on the the stationary wall, the blade-tip and blade, and the hub surface.
Under the circumstances, if the total heights for the prism-layers be different due to the tip-clearance, the mesh structure could not be properly distributed for the computational domain, i.e. not uniformly distributed!
In case, the user's manual says that there are at least 2-3 tetrahedral meshes between the prism-layers.
How could I overcome this kind of problem...? (In this case, I wonder if the hexahedral-meshing should be adopted or not.)
Thanks a lot in advance.
Old   November 6, 2006, 15:10
Sounds like you either need to use a smaller initial height in the tip region. You could also mesh this in a hexahedral mesher but with a little thought a tet/prism mesh should work.
Old   November 7, 2006, 02:54
Turbomachinery
Dear Friend,
Could you make the prism-layers with good quality on both the blade-tip and the blade-around surfaces?
Due to the small gap between the blade-tip and the stationary wall, the total thickness of prism-layer on the blade-tip becomes very thin comparing with the prism-layer's thickness of the blade-around surface, which makes the whole structure of the prism-layers be irregular, i.e. the total thickness of each prism-layer may be different from the one designated by the user.
How could you handle this problem...?
With my best regards,
[ICEM] Hexa meshing of impeller and diffuser assembly Nitin Dewangan ANSYS Meshing & Geometry 14 September 13, 2016 09:41
[ICEM] Meshing a centrifugal compressor impeller Mitpostdoc ANSYS Meshing & Geometry 8 February 25, 2011 10:51
Best Search algorithm for Unstructured Meshing? Dinesh Godavarty Main CFD Forum 3 September 3, 2003 13:16
how to do a good meshing using unstructured mesh nikita FLUENT 6 August 22, 2003 21:06
unstructured meshing Michelle FLUENT 1 February 7, 2003 05:23
