Does Ansys workbench can import .cdb file as load? |
Hi:
i export some temperature and stress to .cdb files in CFX. And i want to use the files as load in Ansys workbench, can i do it successfully? thanks in advance!!!~~~ |
is there anyone help me or give me some advise~~~
thanks a lot~ |
Fred Pier
Rep Power: 16 ![]() |
I have the same problem.
I would like to import a .cdb file ( from fluent) in workbench , is it possible? information : it is a 2d problem , i juste want to import pressure on a edge. Thanks! Fred |
Rep Power: 21 ![]() |
Something like the following Command Snipet in WB should do it:
/PREP7 /inp,filename,sfe /SOLVE |
Fred Pier
Thanks Stumpy for your reply .
I will try it ! thanks again! Fred |
Fred Pier
Helo stumpy ,
I have tryed a lot , but i con't import load . Could you explain more your solution please? Whant kind ( and extension) of file can i import? Where do i generate this file ( cfd post, fluent)? I tryed the export from fluent in cdb, but i failed , the Snipet was not enough readable. thanks again! cheers fred |
Masashi Ohbuchi
If you mentioned about cmdb (Meshing) not cdb (Mechanical APDL), you can import by File->import.
If your cmdb file contains CFX-Mesh data created by release 10, you should import by release 11 first and save as release 11 data. |
How to import Autodesk Inventor .ipt file into ANSYS FLUENT? | soetommy | FLUENT | 0 | September 27, 2011 00:35 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
