April 4, 2021, 10:26 |
H2 material data
Alberto Fernandez
Rep Power: 5 |
I'm a little bit new in CFX and I am working with with cryogenic H2 gas. Some characteristics such as density are dependent on temperature at this temperatures. Is there any H2 material file to add it or what should I do?
April 5, 2021, 10:13 |
Rep Power: 32 |
For H2 in a gaseous state, the density is always a function of temperature.
are you asking for real gas properties for H2? How to obtain them? How to model H2 is such thermodynamic condition? ANSYS CFX provides the homogenous binary mixture approach, and as well as Real Gas modeling (Redlich-Kwang, Peng-Robinson, etc). On the Materials folder, right click on it and select Import Library Data. A new panel will show you the current database, you then select the Browse Folder icon and select another material database based on your needs. Check carefully each database, H2 may not be in the one you expect, say Combustion.
April 6, 2021, 09:24 |
Erik
Rep Power: 23 |
You need to choose how your material needs to be defined based on what you are simulating. There are many options for defining material properties.
Continuity Equation for multicomponent simulation | lordluan | CFX | 15 | May 19, 2020 18:36 |
Problem in importing new material added in engineering data library to CFX-Pre | Ghada | CFX | 5 | February 27, 2018 13:21 |
Optaining Material Data | Friendly | Structural Mechanics | 0 | January 8, 2018 06:53 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
