April 18, 2021, 03:14 |
Losses in a channel
Rep Power: 14 |
I am studying losses in a flow domain with several vanes. I use static entropy contours to find the location of high entropy generation. My results show that there is high entropy generation which is concentrated near to a solid boundary. Is there a way to distinguish between the type of losses such as boundary layers, flow separation, mixing loss, tip leakage, secondary (endwall) loss?
April 22, 2021, 06:15 |
Rep Power: 17 |
Wouldn't it be better to locate such regions with an Isosurface, rather than contours [in a plane]?
To the question on determining the type of loss, I don't think you will get much help from CFX itself on this. Though, a combination of experience and physics understanding, and probe points/surfaces, will make you able to measure the change in quantities. For a channel flow, monitoring Pressure would seem like an obvious place to start. |
3D open channel hydraulic jump would not jump | roi247 | FLUENT | 3 | March 11, 2020 03:46 |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 16:26 |
interFoam Micro channel | 1988 | OpenFOAM Running, Solving & CFD | 1 | January 25, 2015 13:50 |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 11:44 |
tecplot 3D velocity contours inside a channel | vetnav | Tecplot | 4 | July 14, 2010 20:03 |
