2D Simulations
Old   January 25, 2007, 05:44
Default 2D Simulations
Uros
Hallo everybody!
Does anyone know how to create a 2D (quasi) simulation in CFX10? The help file says it's possible, but following those steps I always get a message: "CFX can only operate on Solid Volumes!". I want to create a simple planar rectangular surface with one moving boundary, no inlets and outlets and simulate gas behaviour bounded by the geometry.
Thanks a lot for any replies! Greetings,
Uros.
Old   January 25, 2007, 06:47
Default Re: 2D Simulations
Joe
Use the forum search function.
Old   January 25, 2007, 16:27
Santiago Orrego.
You have to extrude, 1 cell deep, in your mesh software.
Old   January 26, 2007, 07:07
tarek
You need to create a volume, to simulate 2D simulation, so u have to choose one unite in the Z direction, and ur reall values in the (x,y) direction. Tarek
Old   January 27, 2007, 04:30
Deepak Narayan Ramanath
Basically, you have to know that CFX is a 3-D solver and not a 2-D, therefore, you need to have a 3-D mesh for CFX. For simulating 2-D, extrude the mesh (one cell thick) in the Z direction. Or if you are trying to do a 2-D axisymmetry, then extrude by rotation by say 1 degree or max 5-degree, depending on the complexity of the model. Since you would be having a slip-wall boundary condition on those extruded symmetry faces, the fluxes calculated are equated to 0. This acts as symmetry BC.
Old   January 29, 2007, 13:36
Robin
Don't use a free slip wall, use Symmetry or, if there is swirl, create a Periodic interface.
-Robin
Old   January 29, 2007, 20:22
Bak_Flow
Why not Robin....?
Regards,
Bak_Flow
Old   February 24, 2007, 08:04
Robin
Hi Bak_Flow,
There is a subtle difference in the discretization at the wall. A free slip wall will not enforce a zero gradient, whereas a symmetry plane will. How the solver does this also affects the calculation of gradients which are used for second order terms. To make a long story short, if you have a grid one element thick and use a free slip wall the advection term will only be first order upwind. So use symmetry.
Regards, Robin
Periodic boundary conditions in 3D Eulerian granular flow simulations dsm FLUENT 4 March 2, 2012 19:04
Hardware selection for steady/unsteady incompressible, turbulent and cht simulations maddalena OpenFOAM 2 July 13, 2011 08:55
Cumulative continuity error large in parallel simulations xiao OpenFOAM 3 March 7, 2011 04:13
Timestepping in two - phase Simulations using RSM challenger85 CFX 0 January 4, 2010 05:00
URANS and Transient Simulations bob Main CFD Forum 0 October 1, 2003 03:54
