moving mesh
Old   March 11, 2007, 03:15
Default moving mesh
bi
Hi all,
I am facing a rotating mesh problem. In my case, an ellipse wall in XY-plane rotates around its center axis (Z-axis) with a sinusoidal function alpha = sin(omega*t). At initial time (t=0), the ellipse is horizontal in X-axis. I define two functions for mesh movement as follows, XDIS = r*cos(omega*t/1[s]+theta)-r*cos(theta); YDIS = r*sin(omega*t/1[s]+theta)-r*sin(theta); omega = 2*pi; Time for transient analysis is t = 1 [s]; TimeStep = 0.001 [s]. My problem can not be solved even though the mesh is very fine and the ellipse wall was set to Specified Location or Specified Displacement. I think that there must be a problem in my mesh movement functions. I still don't know how to treat them. Could you please suggest any rotating mesh function for me?
Thank you very much for your help.
Old   March 11, 2007, 04:28
Default Re: moving mesh
If the mesh only rotates then use a rotating frame of reference and forget about moving mesh.
Regards, Glenn Horrocks
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 04:15
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Waves halted by moving mesh Piotr Czajko COMSOL 1 November 24, 2007 02:00
