Meaning of Range of Variable like Global velocity or Local velocity in CFD post? |
July 19, 2021, 06:57 |
Rabi Pathak
Rep Power: 5 |
I am trying to plot a velocity field after a simulation. In the CFD-Post, while plotting the contour, I am getting the option as select Range : Local or Global. Both are giving different type of velocity profiles. What does this local and global velocity represent?
July 19, 2021, 07:09 |
Rep Power: 143 |
Local = the velocity range on the object (in this case, what object you are basing your contours on)
Global = the velocity range in the entire simulation
July 19, 2021, 07:24 |
Rabi Pathak
Rep Power: 5 |
What objects in the sense like the objects inside the domain or the object which I have selected my contour on like I have made a plane and made a contour over it, so here my plane becomes the object? Or if I have a airfoil in a domain, then my airfoil becomes the object?
Just curious |
July 19, 2021, 07:57 |
Rep Power: 143 |
As I said, the object you are basing your contours on. So it sounds like it is the plane you are making the contours on.
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
