RADIATION AND PARTICLE TRACKING
Old   March 14, 2007, 16:10
Default RADIATION AND PARTICLE TRACKING
MARCO SIMONE
Hi EVERYBODY!
I want to simulate a solid particle tracking in a continuos nitrogen dominium in CFX 5.7.
I want nitrogen to absorb no radiative heat, therefore I set the radiation model to none; but I want the solid particles to absorb radiative heat.
How can I do?
Please answer me!!!Thank you!!!
Old   March 14, 2007, 16:22
Default Re: RADIATION AND PARTICLE TRACKING
You will need a radiation model to do this so turn it back on. Set the absorption coefficient of N2 to 0 so it does not absorb any radiation.
Old   March 28, 2007, 04:44
Mastro
Thank you for your answer Glenn!
I set the nitrogen absorbtion coefficient to zero but the simulation result was the same of the simulation without any radiation model switched on: the particle temperature was the same in both simulations.
Do you have any other suggestions?
Thanks a lot!!!!
Can't set absorption coefficient for inert particle lauripar FLUENT 1 May 9, 2012 15:09
Selecting the appropriate multiphase model and radiation model panos_metal FLUENT 0 June 18, 2010 07:58
particle tracking mike CFX 3 April 17, 2006 00:05
About particle radiation kris Siemens 0 July 31, 2005 20:45
Radiation to particle shery FLUENT 0 February 16, 2001 17:44
