Fatal overflow in linear solution
Old   March 26, 2007, 14:19
Default Fatal overflow in linear solution
Ravi
Frds, I am solving a pipe flow problem in CFX but i am getting an error in solver, the message shown after failure is "ERROR #004100018 has occurred in subroutine FINMES. Message: Fatal overflow in linear solver." Please if anybdy has idea abt it pls help.
Thanks Ravi
Old   March 26, 2007, 16:09
Default Re: Fatal overflow in linear solution
Juan Catelén
Within Advice on flow Modelling, on the manual, you will find some recommendations to see what to do with this kind of errors.
Old   March 27, 2007, 03:13
Ravi
I am not really clear about the solution given in solver advice. if i change the outlet boundary to opening boundary, the solver solves the problem but when i draw the velocity vector the direction of vector is opposite to the expected one and which i feel is not the realistic one. so please let me know somthg more abt it....
Thanks Ravi
Old   March 27, 2007, 08:36
Juan Catelén
You should simplify the model, at least until you find a good result and then you will be able too add more complexity. Could it be that there is a reflux next to the outlet? Can you move away the outlet? Can you describe to me better the system?
Old   March 27, 2007, 13:35
Ravi
Thanks Ravi
Old   March 27, 2007, 20:08
Johnny
Try a finer mesh, smaller timestep, and double checking your boundary conditions to ensure you haven't set things up backwards.
Old   March 29, 2007, 06:44
Ravi
Thanks Frds,
I tried with finer mesh and readjusted the outlet to further distance and the solution obtained was very good. The guidance worked out. Thankyou so much......
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Solution variables goes outside upper limit -how to localize fatal overflow occurance Dimone CFX 2 January 21, 2011 06:35
Please help me out: linear solver Overflow sswing CFX 14 October 25, 2010 08:30
Fatal Overflow when using RNG k-e Pascal CFX 2 February 5, 2008 16:41
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
