boundary conditions for compute resistance of ship |
hello everyone!
I'm doing a two-phase flow simulation for calculating the total resistance of a ship. I made 1 million hexa-mesh in a 1/4 cylinder with one conjuncted interface. I tried to execute the transient computation. I'm using a parallel system to do my work. I looked at some discussions here, tried many times to find a correct boundary condition, but very difficult. my computation always fails. My question is how to give the boundary conditions to do the simulation. I want to know the total resistance including the wave resistance. I gave BC like this: homogenous model; standard free surface; mixture model 1[mm] SST or K-epsilon model; velocity inlet pressure outlet ( rho*g*(h-z)*vfwater ) noslip wall ( 1/2 shipbody ) moving wall ( surrounding 1/4 cylinder walls ) symmetry middle wall What should I do now? how to solve this kind of problems? thank you for your kindly answer. |
Free-slip, where the shear stress at the wall is zero (τ = 0), and the velocity of the fluid near the Wall is not retarded by wall friction effects. In a multiphase case, if one fluid uses a Free Slip Wall, other fluids can use any Wall influence condition.
so...... |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
Ship resistance | tobino | FLUENT | 0 | June 27, 2011 20:31 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Fluent accuracy and boundary conditions | Paolo Lampitella | FLUENT | 0 | June 12, 2008 06:25 |
