September 17, 2021, 03:24 |
source term
Zese
Rep Power: 12 |
Dear friends
I have a question about adding a source term to cfx. I want to amplify the flow by f=A*exp(w*t) where A is the amplitude and w is the frequency. there is no flow injection just some waves are added in two small regions. do you know how I can do that in either CFX or Fluent? Best regards |
September 17, 2021, 07:19 |
Rep Power: 143 |
You need to think about what physically realistic process could generate the effect you want, and then you develop a source term to implement that process.
So maybe applying a force per unit volume over a region, and the force oscillates? Or maybe a region of fluid with its displacement defined to oscillate? Or a plate in the flow which oscillates and moves the fluid?
[openSmoke] LaminarSMOKE compilation error | mdhfiz | OpenFOAM Community Contributions | 7 | October 4, 2022 13:57 |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
Source term for EVAPORATION in Energy Equ. - technical difficulty ? | Kummi | OpenFOAM | 1 | September 9, 2019 09:32 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
