Different fluid problem
Old   May 3, 2007, 00:35
Default Different fluid problem
prateek jain
I have a problem in CFX that when I defined two fluid for different domains it automatic takes same fluid I am using CFX-10
Old   May 3, 2007, 09:11
Default Re: Different fluid problem
opaque
Dear jain,
what type of problem are you tring to solve.. Is it two-phase problem? or two separate fluid streams, as in a heat exchanger?
For the latter, you need to setup CFX-Pre in the "non-constant" physics mode.. The topic has been discussed several times in the forum..
Opaque
VOF - fluid property problem weechristo FLUENT 1 April 11, 2009 15:08
Fluid Structure Interaction. Tut 20 like Problem Aziz CFX 7 May 4, 2005 19:24
Problem in fluid zone!!! STK FLUENT 2 September 1, 2004 15:27
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 05:49
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 Mohammad Al-Shannag Main CFD Forum 1 July 16, 1999 11:28
