April 25, 2007, 03:58 |
Redlich kwong equation of state for drysteam
I m using redlich kwong eqn of state for dry steam calculation in a compressor problem with certain temp and pressure as per steam table as a reference state with ref enthalpy and ref entropy values specified zero. But in post processing after a converged solution,the density variations with pressure are not as per std steam table,also the Rothaly is quiet large compared to the pressure and so is the temperature. Does anyone have any idea about how to use Drysteam in cfx11 for compression process.
April 26, 2007, 16:11 |
Re: Redlich kwong equation of state for drysteam
Do you use total energy?
Gert-Jan |
April 27, 2007, 00:41 |
Yes gert i m Using Total Energy.
May 8, 2007, 16:20 |
what steam table do you use?
what p range are you compressing over? perhaps iapws in cfx11 is the solution |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
