change timestep after a certain iteration number |
May 31, 2007, 05:03 |
Hi, I observe that my problem starts to diverge after say 60-70 iterations, but it is soon rectified when I reduce the timestep. But during a batch run I would like to do the same. Is it possible to change the timestep after a specified iteration during a batch run (command line)?
Thanks... |
May 31, 2007, 08:12 |
Re: change timestep after a certain iteration numb
I do it every day....
Physical Timescale = min(1e-2[s],max(5e-3[s],2e-2[s]-citern*1e-4[s])) Plot it in Pre to find out how it looks like. Gert-Jan www.bunova.nl |
June 1, 2007, 00:58 |
Thanks a lot Gert-Jan,
Now it strikes me...or inturn I can also use a fuction in PRE |
June 1, 2007, 03:27 |
Hi! Gert-Jan, I think This is also useful to me, could you please explain the meaning of "min(1e-2[s],max(5e-3[s],2e-2[s]-citern*1e-4[s]))", since I am quite new to CFX. Thanks
June 1, 2007, 04:56 |
It is mathematics. The only unknown thing is citern which is the current iteration number. You can also use aitern which is the accumulated iteration number.
Just play around in Pre or a spreadheet to see what the function does... Gert-Jan www.bunova.nl |
June 3, 2007, 05:17 |
Hi. There is another way is to use step function. suppose timestep upto 60th iteration is 0.025 [s] and after 60th iteration it is tobe reduced to 0.002 [s], you may use following step function, Timestep = 0.025[s]*step(aitern-60)+0.002[s]*step(60-aitern).
Sameer |
how to increase "Newton Pressure Iteration Limit" | kus | CFX | 9 | April 21, 2013 01:54 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
when should we change max continuity loop number | steven | CFX | 2 | March 7, 2007 11:58 |
Change Courant number from UDF | HS | FLUENT | 0 | December 1, 2005 05:16 |
how to change the number of cset and vset | lenson | Siemens | 3 | October 10, 2005 06:40 |
