General grid/element size and time step questions
Old   May 24, 2007, 02:34
Default General grid/element size and time step questions
stu
Just a question regading grid size and time steps for transient analysis.
Question : In order for the fluid from one cell to reach the next cell, does the time step need to be long enough for the distance=velocity*time step relationship to be true? eg if my time step and input velocity is such that ts=0.1 secs, input vel = 10 mm/s and I have a gid/mesh/element size =10mm, hence in 0.1 secs, the fluid has 'travelled' 1 mm, it has not reached the next element by the end of the time step. Will this work? Can you run a simulation like this?
What happens if the reverse is true, the input vel was 800 mm/s, the fluid would have travelled across 8 elements in the time step. Would this work, can you run a sim like this, or would the results be useless?
Are there any general rules that govern velocity, mesh size, and domain size?
Thanks Stu
Old   May 24, 2007, 05:37
Default Re: General grid/element size and time step questi
Joe
Yes.
CFX is an implicit code so theoretically the Courant number (look this up) can be arbitrarily large.
Generally though try to keep the RMS Courant number under 5.
Ultimately time step selection must be governed by timestep independence studies analogous to mesh independence studies.
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Is there a way to write the time step size, time a may FLUENT 6 November 22, 2009 11:52
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
