Turbulence quantities solved by 1st order scheme?
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   May 27, 2007, 10:45
Default Turbulence quantities solved by 1st order scheme?
Damien
I read some previous post that the turbulence quantities in CFX were solved using first order scheme. Is that because of the time derivative term in the turbulence equation and the first order scheme has to be used to ensure bounded solution?
Thanks for your kind advice.
Old   May 27, 2007, 16:34
Default Re: Turbulence quantities solved by 1st order sche
Gert-Jan
For turbulence, production and dissipation are more important than convection. In other words, turbulence is hardly transported by the flow. Therefore, usually upwind is sufficient.
However, if you want to want to study mixing (reactions of chemical component. scalars, energy. etc.) you might need to check high resolution. I have seen applications where this lead to considerable improvements.
Gert-Jan
www.bunova.nl
wooang7031 likes this.
Old   May 29, 2007, 01:56
Damien
Okay, thanks. If I choose high resolution scheme, it should now be 2nd order, right? I remember someone in this forum mentioned that turbulence equation is always solved in first order. I'm a bit confused now.
Old   May 29, 2007, 07:54
Gert-Jan
Close to second order. You can check the order by looking for the beta value in CFX-Post. If you really want 2nd order, then you should choose a specific blend factor of 1.
Gert-Jan
Need help with 1st order FV scheme Andrei Chernousov Main CFD Forum 1 March 14, 2013 03:37
TVD scheme limitedLinear only first order accurate? Rickard.Solsjo OpenFOAM 0 July 7, 2011 04:53
Order of accuracy: 1st or 2nd order? fisch OpenFOAM Running, Solving & CFD 2 July 6, 2011 04:37
Changing LimitedLinear to blend with 2nd order upwind instead of 1st order upwind stevenvanharen OpenFOAM Programming & Development 0 April 11, 2011 05:54
Convergence sensitivity to inlet turbulence quantities? gravis FLUENT 0 October 25, 2010 10:00
