ANY FLUENT WIZARD AROUND??
Old   May 29, 2007, 10:32
Default ANY FLUENT WIZARD AROUND??
Amr
I am looking for a UDF that calculates the integral of the pressure forces (resultant of lift and drag) for an incompressible flow past a cylinder in 2d. Then, via a certain differential equation -not known yet- the displacement of the cylinder's center of gravity will be calculated then fed to the solver to move the whole cylinder and the mesh consequently. That is supposed to be made in transient simulation of course. So, this UDF will be used in the moving mesh model so as the simulation works as a coupled fluid-structure interaction.
Now, could any body give a hand here?
Cheers, Amr
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
ANY FLUENT WIZARD AROUND?? Amr FLUENT 0 May 29, 2007 10:33
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
