Pressure temperature variation
Old   June 21, 2007, 23:01
Default Pressure temperature variation
Dev
Dear experts,
I am trying to simulate pressure changes as the the temperature increases with time but I am unable to do that. What I simulated was a tube and shell arrangement. Hot fluid passes through the tube side and heats up the cold fluid in the shell side. I want to study the change in pressure as the temperature increases with time. I know the inlet temperature and pressure and also the flow rate for the outlet (these are for the tube as well as the shell side). The solution shows an increase in temperature at the shell side (cold side) but no increase in pressure. Am i doing something wrong here? Please advice.
Thanks in advance.
Dev...
Temperature anomoly at pressure reference cell will.logie OpenFOAM Running, Solving & CFD 22 July 16, 2021 23:26
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Pressure and Temperature UDF for Cell Zone elixer2104 FLUENT 0 February 24, 2011 11:54
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
