Airfoil "Near Leading Edge" Heat Transfer question |
July 5, 2007, 09:37 |
Colleagues... I have a Y+~1 mesh (with associated near-wall mesh spreading), running with the K-omega SST turbulence modeling. The analysis runs around an airfoil section. The approaching flowpath is turbulent (Intensity ~ 5%, dissipation lengh specified), compressible flow. Since I have a refined wall mesh, the boundary layer (BL) is integrated to the wall through the mesh, and heat flux = K*dT/dY at the wall. Near the airfoil leading edge region, does CFX return a heat flux (and HTC)result indicative of the newly forming (ie: laminar boundary layer) with some freestream turbulence influences...or is the heat flux indicative of a turbulent (post-transitional)boundary bayer? Thank you for your insights. Glenn
July 7, 2007, 06:47 |
Re: Airfoil "Near Leading Edge" Heat Transfer ques
Hi Glenn,
To model the laminar to turbulent transition and associated heat transfer effects you will need to turn the turbulence transition model on. If you have not got it on the model assumes the flow is turbulent everywhere. Regards, Glenn Horrocks |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
a question about interface heat transfer | vip_lws | FLUENT | 0 | April 14, 2009 04:45 |
need papers on heat transfer | George | Main CFD Forum | 0 | November 27, 2008 07:42 |
Non-CFD heat transfer question | Adrin Gharakhani | Main CFD Forum | 1 | November 18, 2000 00:14 |
