review of the results about rotation
Like Tree1Likes
  • 1 Post By ghorrocks
Old   May 23, 2022, 21:17
Default review of the results about rotation
Jin Seok Lee
jins9158 is on a distinguished road
I simulated about fan assy's simulation
The fan is sirroco fan which use in ventilation system.
I used below conditons.
1. Inlet condition
-99[Pa]
(because of loss about filters)
2. outlet condtion
80[CMH]
3. rotation condition
1) 1240[RPM]
2) Frozen rotor
3) Full blade
4. solver conditon
1) steady state
2) 1500 iteration, 700 iteration
3) time scale 7.7e -04, 7.7e-03
I simulated 1500 iteration and the time scale 7.7e-04. After that, I additionally simulated 700 iteration by using 7.7e-3 time scale becasue simulation time is short.
In short,
1500 iteration & 7.7e-04 time scale >> 1.15s
700iteration & 7.7e-03 time scale >> 5.39s
So total time is 6.54s
that means 134 rotation and I think that is enough about flow development.
When I simulated, I thought that the result is not good.
(I attached the picture of result)
I want to get some advice.
Please help me.
File Type: zip 220520_huvenW_80_case6_cutoff_increase1_003.zip (63.9 KB, 1 views)
jins9158 is offline   Reply With Quote
Old   May 24, 2022, 02:43
That geometry is almost certainly not steady state. The exit jet is going to flap around, so no steady state solution exists.
See this FAQ for some tips: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
But you are almost certainly going to have to simulate this transient.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 24, 2022, 03:32
Jin Seok Lee
Thank you for replying my question
I also thought I need to simulate transient simulation in my situation.
But, Many researchers has used steady state such as me becasue unsteady require more CPU a lot.
So Are there antoher method for me? I just can use 36 core for simulation because of license limit.
I tried to use local time scale and outlet condition change mass to pressure...
Old   May 24, 2022, 06:59
The only way to reduce a transient simulation to a steady state one is to introduce so much diffusion into it that it all gets smeared out. Then it will be steady state - and horribly inaccurate. If the other researchers got steady state results on a configuration like that then I would be seriously doubting the accuracy of their results.
If there was a way to reduce a transient result to steady state the FAQ would say so. The FAQ really does describe the best path forwards, so please read it.
Old   May 24, 2022, 09:33
Opaque will become famous soon enough
What is the goal of your simulation? Flow features around the non-symmetric area? or just the overall performance of the device?
There are 3 approaches commonly used in the industry to model this device:
1 - Mixing plane between the rotor (cage) and the casing (volute)
2 - Frozen rotor approximation instead of mixing plane, and study the different orientations of the rotor (cage) with respect to the non-symmetric section. For this specific case, it seems any orientation will do since there are some many "blades" in the cage that a minor rotation will look the same as the previous configuration.
3 - Full unsteady simulation (perhaps a 4th one will be transient blade row with pitch change, but never done it myself with this use case)
Despite the crude approximations of 1 and 2, the quick solutions (hours) allow engineers to make quick design decisions (helped with additional experimental data) instead of waiting days/weeks for an unsteady solution for a single operating condition. Unsteady is only used when detailed flow features are essential (no modeling error accepted) to make the next decision.
Opaque is offline   Reply With Quote
Old   May 24, 2022, 21:18
Jin Seok Lee
Thank you for your concern.
Now, I am simulating transient simulation by inital value using steady state result. I just set total time 0.05s because I want to one rotate the impeller. simulation time are going to need about 3days.
I know the rotation is short, but it spend much time to simulate transient.
Thank you.
Old   May 24, 2022, 21:26
Jin Seok Lee
Where is the vortex, and based on this, we are trying to reduce the noise by improving the inside of the fan case.
So I now simulating transient simulation although one roation.
Old   May 25, 2022, 08:06
Modeling one rotation will do nothing for you. It may take more than one rotation for the solution to "converge" to its final unsteady state. Unfortunately, you have to run it until a repeatable pattern of some kind can be identified; otherwise, it is just a snapshot of something in development
Old   May 25, 2022, 20:42
Jin Seok Lee
When I see my processing result about sovle manager, It seems like convergence althoght the impeller rotatate one.
As your advice, I'll see if the convergence goes well.
Old   May 26, 2022, 02:46
Gert-Jan
Gert-Jan will become famous soon enough
Do you know what the source is for the noise? Does the spectrum tell you anything?
Gert-Jan is offline   Reply With Quote
Old   May 26, 2022, 05:36
If you are trying to reduce the noise then the transient flow might be the source of it. If the frequency of the flow flapping about in your transient analysis is the same as an important frequency in the noise spectrum then you know that you are modelling an important source of the noise.
Opaque likes this.
bad heat transfer results with low y+ me45 OpenFOAM Running, Solving & CFD 0 April 29, 2020 11:56
Workbench results not matching CFD-Post newbietocfd ANSYS 1 December 4, 2019 11:55
Error Interpolating Results onto New Mesh nammeh CFX 1 March 26, 2019 12:08
Simultaneous rotation and translation yields strange results with gmsh BPeters Mesh Generation & Pre-Processing 2 November 19, 2018 02:52
Creating a tool to interpolate results Luis Batista OpenFOAM Running, Solving & CFD 2 April 11, 2013 08:15
