Marta
Rep Power: 5 ![]() |
Hello!
I've a transient simulation with approx. 35.000 timesteps. I want to generate chart of changing pressure in time in created point but my RAM can't manage. What I want to get is an expression or function which takes only even or odd timesteps or every third or fourth timestep. Thanks in advance for any help :) Best regards, Marta |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Personally I find the charting options in CFD-Post very limiting, if this was me I would send the data to a monitor point. Then it will be available in Solver Manager to chart there or export as a csv file to a more sophisticated graphing package like matlab or python. Then you do not need to fire up CFD-Post at all.
To answer your question - I cannot see any options in CFD-Post to do what you request. But I am not an expert in charting in CFD-Post, have a look around and see what you can do. But next time you run this do as I suggest in the first paragraph and you will not need to use CFD-Post at all to generate these charts.
Marta
I don't know if I understand you properly. What I figured out from your reply is setting two expressions as output parameters: 1st - maximum value of pressure in point and 2nd - current time step. In this way I should get a table with maximum values of pressure in designed point in every time step.
In my opinion it should work. What do you think? |
Rep Power: 33 ![]() |
If I understood Glenn correctly, he meant
1 - Create monitor point in CFX-Pre, using coordinates 2 - Select Pressure as the variable to be monitored at the location in (1) 3 - Monitor transient signal in the SOlver Manager as the solution progresses. 4 - Once solution is finished, export (right click on the SolverManager plot) to an external file 5 - Alternatively, create chart in CFD-Post and select Monitor Data in the Data Series tab. hope the above helps,
Marta
Hi Opaque!
Thank you for clarifying me these steps. I've tried to do what you wrote: 1. I created a point, using coordinates point.png 2. Select Pressure as the variable to be monitored - in this step I'm not sure how to set parameters correctly. Can you help me with it? 3. How to manage 3rd step? The picture below presents settings of created variable 'pressure' in CFX-Pre. 'Variable Type' allows me to choose one of three options: Specific, Volumetric and Unspecified. I chose first one - Specific but I'm not sure if this is correct. What do you think about it? new variable - pressure.png |
No, you are looking at the wrong bit. You want a monitor point, which is in the output tab.
Marta
Hi there!
Okay - what I've done this time is setting expressions (probe of pressure and WSS in created point) as an outputs parameters. CFX + Parameter Set.png What I got is a table with designed points. Apart from these parameters I also added a Current Time Step as an output parameter. Do you think it is necessary? Parameter Set.png I hope this is what you meant ![]() |
Um, no. That is not what I meant. You get the data out using Solver Manager, not as a parameter into Workbench.
Doesn't Opaque's post tell you exactly what to do? If you do not understand Opaque's post why don't you ask about what you do not understand?
#9 |
Marta
Hi Glenn, thank you for your answer. I will follow your advice and ask Opaque some questions.
#10 |
You ask questions to the forum, not to specific people. So post your question here and we will try to answer it.
#11 | |
Marta
Can you tell me how to do it correctly? |
#12 |
To create a monitor point,
1 - In the Outline in CFX-Pre, there is a Output Control item, open it 2 - There is a Monitor Tab 3 - Insert a Monitor Point, check available options, and select what you need. I think these steps are described in several tutorials, so it should be clear (and perhaps explained better than here) if you do some of them.
#13 |
Marta
Thanks! Now it works!
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 07:23 |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
Problem regarding producing streamlines from surfaces in Ansys CFD post | gauthamnarayan | ANSYS | 6 | June 8, 2015 07:33 |
Problem regarding producing streamlines from surfaces in Ansys CFD post | gauthamnarayan | Visualization & Post-Processing | 0 | April 23, 2015 16:07 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 00:30 |
