separate time step for mass fraction?
Old   August 10, 2007, 06:40
Default separate time step for mass fraction?
joe
hello, i simulate a problem with cfx 11 including a mass fraction. since that mass fraction moves with a very low settling velocity (downwards slip velocity)- in comparison to the flow of the constraint, i would like to solves the equation of the mass fraction with a bigger time step than the "global time step size". Does anyoune kmow if this is possible with a transient simulation? thanks! joe
Old   August 12, 2007, 18:30
Default Re: separate time step for mass fraction?
Why would you want to do this in a transient simulation? You won't get a true time history then. You should be able to use quite a large timestep if the bulk flow is pretty much steady state.
An alternative if the velocity and mass equations do not change but the mass fraction evolves then you can turn the velocity and mass equations off and only solve the mass fraction. This will speed the simulation up hugely if this assumption is valid.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Restarting interDyMFoam hsieh OpenFOAM Bugs 4 January 25, 2009 15:19
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
