ERROR #002100048 in Solver
Like Tree2Likes
  • 1 Post By ghorrocks
Old   May 17, 2014, 12:44
Default ERROR #002100048 in Solver
Muhammad Arif
arif.hmc3 is on a distinguished road
This error occur while solving the nozzle flow , I am a bignner can someone tell me how I resolve this issue, Yours suggesion will be highly appreciated, Thanks
ERROR #002100048 has occurred in subroutine SU_BNEXT. |
| Message: |
| All vertices for a fluid domain lie on boundaries. This is |
| considered to be a fatal error because control volume gradients |
| cannot be calculated, leading to serious discretization error. |
| A common cause for this error is a mesh which is only one |
| element thick, without symmetry or 1:1 periodicity on the lateral |
| boundaries. If you have this situation, and the domain is |
| two-dimensional, please change the lateral boundary conditions |
| to symmetry or 1:1 periodicity. Alternatively, for |
| three-dimensional simulations, please ensure that your mesh |
| has at least two elements across. |
| Execution is terminating. This error message can be bypassed by |
| setting the expert parameter 'boundary vertex check = f', but |
| be aware that doing so may lead to sigificant solution error."
arif.hmc3 is offline   Reply With Quote
Old   May 18, 2014, 06:34
The error message is pretty clear, isn't it? It tells you exactly what you need to do.
holzkiste likes this.
Old   May 22, 2014, 14:16
Muhammad Arif
Sorry , I am a bignner, but now a bit learned..
Old   May 22, 2014, 18:42
OK, let me repeat what the message says:
You cannot have a domain which is 1 element thick. You will need to make it a few elements thick.
Note you can have a 1 element thick domain with symmetry and periodic boundaries. But all other types of boundary are not possible.
Old   May 23, 2014, 14:23
Muhammad Arif
yes, I got it, Thanks for reply...
Old   May 26, 2014, 02:51
Default Near Wall Mesh Denisty
Muhammad Arif
Dear Sir, Can u tell me plz how to increase the near wall mesh density in nozzle ?i am attaching geometry along with some rough mesh.
Old   May 26, 2014, 08:54
Make the mesh finer. It is a pretty simple concept.
I also note that your mesh has some massive jumps in size. This is bad. You need to transition the mesh when you change size.
Old   May 26, 2014, 09:46
Muhammad Arif
Thanks for your reply. Actully I Dont know how to make fine mesh near the wall in ICEM. I want to capture sepration of flow , so need more dense mesh near wall. Plz dont mind , I know I mputting very basic question but I try to that but not succeful yet.
Old   May 26, 2014, 18:27
This is all covered in the ICEM tutorials. You can get them on the ANSYS customer page on the ANSYS website.
Old   August 22, 2014, 15:00
Hesam Moghaddam
hesamking is on a distinguished road
Try switching to local parallel run in the CFX-solver instead of serial and the simulation will run without any problem!!!!
Hesam
hesamking is offline   Reply With Quote
Old   September 5, 2022, 02:34
Default Master of Science in Chemical Engineering (process Engineering stream)
  #11
Ethiopia
ermiasa100@gmail.com is on a distinguished road
dear sir, the same message occurred in my simulation please tell me the step how to thick
| Message: |
ermiasa100@gmail.com is offline   Reply With Quote
Old   September 5, 2022, 03:07
I think I have said that before......
karachun likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   September 5, 2022, 03:53
Default Master of Science in "Chemical Engineering PROCESS Engineering stream)"
  #13
Ethiopia
yes, sir, you said it but the response is not clear,i need more explanation, please, how to thick more elemnts
Old   September 5, 2022, 04:59
Gert-Jan
Gert-Jan will become famous soon enough
If this is an ICEM problem, then better ask in the ANSYS Meshing and Geometry forum, and add some pictures to see what you try to do.
Gert-Jan is offline   Reply With Quote
Old   September 5, 2022, 07:26
Default Master of Science in "Chemical Engineering (Food Engineering stream)"
  #15
Ethiopia
okay thankyou
Old   September 6, 2022, 09:15
Ethiopia
any one can you help me
Old   September 6, 2022, 10:32
Gert-Jan
Your geometry (or at least a part) is 2D. Meaning, you have a surface mesh. In Fluent you can do this, not in CFX. In CFX your 2D part requires an element in the third direction to create a volume. This can be 1 element. Then you can solve your 2D case using CFX with symmetry BC on the front and the back surface.
However, your problem seems not to be in the solver, but in the geometry or in the mesher. So if you don't know how to solve this, then go to the appropriate forum and ask there with some pictures. A picture says more than thousand words.
https://www.cfd-online.com/Forums/ansys-meshing/
Old   September 6, 2022, 10:41
Opaque will become famous soon enough
If you are modeling a 2D case (with one element thick), and you have the wrong boundary conditions on the "2D planes", you will get this error.
The message says clearly, that your boundary condition on those planes can ONLY be symmetry, or translational periodicity using a 1:1 option. If you think those options do not apply to you, you likely do not have a 2D problem and your whole approach is incorrect from the start.
Opaque is offline   Reply With Quote
2d cd nozzle
Fluent Adjoint Solver? ex10148 FLUENT 16 September 28, 2018 08:11
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
3d vof Smaras FLUENT 2 February 19, 2013 06:58
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
