September 10, 2022, 19:15 |
Supersonic Ramp Simulation
Gurjot Ahuja
Rep Power: 3 |
Hello All,
I am a beginner in Ansys CFX. I have to simulate a supersonic flow Ma=3.2, Air Ideal Gas, 850K for laminar conditions, frictionless walls to analyze shock waves and expansion fans. As per the theory, I have to set 5 independent variables as inlet conditions. So, I can set Total Temperature, 3 x Velocities directly from the given conditions and I am deriving Total Pressure for Inlet from Isentropic Relations and Ideal Gas Law. Is my approach correct to find the total pressure with is coming around 48.5 bar? For Outlet, I am setting supersonic flow conditions in CFX Pre When I am using Total Pressure as 48.5bar, my simulation is not converging at all. Please help to resolve these issues. Kind Regards. |
September 10, 2022, 21:47 |
Rep Power: 143 |
Please read the section titled "Using Boundary Condition" (section 2.3 of the Solver Modelling guide) and "Monitoring and Obtaining Convergence" (section 16.10 of the Solver Modelling Guide).
Make sure the basics are OK before we go too far.
September 11, 2022, 12:46 |
Rep Power: 32 |
If you look at your options for supersonic inlets, you have
1 - Velocity and Total Pressure 2 - Velocity and Static Pressure 3 - Static and Total Pressure There is no need to convert anything, nor use any relationships. Have you tried say M= 1.5, then 2.0, 2.5, 3.0 ? What is the solution for those intermediate flows? What did I miss?
September 11, 2022, 13:56 |
Gurjot Ahuja
Rep Power: 3 |
Thanks for the reply. I will check the documentation.
September 11, 2022, 14:01 |
#5 | |
Gurjot Ahuja
Rep Power: 3 |
My requirement is to do laminar and turbulent simulation only for M 3.2, so I haven't tried other Mach numbers. First, I am trying to set up a laminar simulation. |
September 11, 2022, 17:29 |
#6 | |
Rep Power: 32 |
Regardless of requirements, you must always follow common sense and understand one step at a time. Good luck with your simulations.
ansys, cfx, ramp, supersonic |
2D axisymmetric Supersonic flow simulation | gokenq | FLUENT | 19 | August 5, 2022 13:41 |
supersonic simulation and mesh adaptation | jwang1_09 | SU2 | 0 | September 16, 2014 05:37 |
Inviscid Supersonic Flow Simulation | Alan | OpenFOAM Running, Solving & CFD | 2 | July 27, 2009 03:36 |
Simulation of Supersonic flow | Morshed Alam | Main CFD Forum | 3 | December 24, 2008 05:13 |
Simulation of supersonic flows | Abduri | CFX | 5 | December 8, 2008 19:30 |
