Experimental Results and CFD results comparaison |
saadoudi messaoud
Rep Power: 4 ![]() |
Hello everyone,
I'm a beginner in cfd and I'm doing a steady state simulation for a centrifugal pump using ansy cfx, but I get CFD results less than Experimental Results within 5% deference, So my question, is it necessary to have CFD results more than Experimental Results? Thanks to all. |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Sometimes the CFD results are higher, sometimes lower. There are many, many things which cause errors, so it could be either way.
See FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F And note that a 5% error is very accurate in some types of CFD (eg heat transfer) but very inaccurate in other types of CFD (low Reynolds Number flows). So whether 5% error is good or not depends on what you are modelling and what accuracy you require.
#3 | |
saadoudi messaoud
Comparison of experimental and CFD results for the VA-2 supercritical airfoil | Aurélien | FLUENT | 3 | April 24, 2024 10:39 |
CFD model validation with experimental data | Alsumri | ANSYS | 6 | November 14, 2019 11:14 |
Question about comparison between CFD results and experimental data | idomeneo | Main CFD Forum | 2 | June 18, 2018 01:35 |
How to compare experimental and CFD results | vigii | Main CFD Forum | 0 | November 25, 2014 00:52 |
CFD results not close to experimental results | cider | STAR-CCM+ | 0 | July 8, 2013 07:53 |
