FSI-time dependent load in cfx10.0
Old   September 11, 2007, 10:46
Default FSI-time dependent load in cfx10.0
siavashghassemi
hello, i am working on a fsi simulation in cfx10.0.load is a pressure like "sin 5t".(t is time) but cfx in post processing doesn't accept t.how can i apply this load?should i write a fortran program?can anyone guide me? thanks.
Old   September 12, 2007, 05:12
Default Re: FSI-time dependent load in cfx10.0
V. Kumar
How can you define loads in CFX-POST? In order to define load or a boundary condition (B.C) you have to go either to ANSYS or CFX-PRE. If it is load on the structure you can edit your ANSYS input like following under /SOLU or /PREP7:
nsel,s,..... !!with nsel select you nodes where you want to apply time-dependent load
*dim, press,table,100,1 !define a variable array e.g. press of length 100
delt=1e-4 !define size of time-step
FREQ=10 !define freqency e.g. 10 Hz
pi = 4*atan(1) ! define your Pi or pi = 3.14157
omega = 2*pi*FREQ
p_max = 10 ! amplitude of the load
*do,tt,0,100,1
press(tt,0)=tt*delt
press(tt,1)=p_max*sin(omega*tt*delt)
*enddo
SF,all,PRES,%press% ! apply pressure load vector on selected nodes
If you want to apply a B.C on the fluid side, this can be done in CFX-PRE. In CFX-PRE a time-dependent B.C can be set by CEL which is quite easy using variable "t". Refer to CFX manuals for this.
Old   September 15, 2007, 10:28
siavash ghassemi
as you wrote i could apply a time dependent b.c in cfx-pre with no error.("sin t" as a mesh displacement in y direction).but when i want to obtain a solution in cfx-solver(start run) an error massage displays that "t is not an angle"! how can i solve this problem? thanks, s.ghassemi
Old   September 16, 2007, 03:28
V. Kumar
ofcourse "t" is not an angle.
Here is an example:
pi = 4*atan(1)
freq = 100 [s^-1]
theta = 2 * pi * freq * t
disp = 0.01 [m] sin(theta)
this should work.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
FSI time YY CFX 0 April 25, 2008 12:38
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
Repeating same time steps (FSI). cjtune Siemens 0 February 19, 2003 23:05
