Daniel
Rep Power: 9 ![]() |
is there a way to calculate the cavity length in a pump simulation with the cavitation model ? I would even like to stop the solver when a certain cavity length has been reached, so I can calculate the NPSHi for a given flow. I tried to work with IsoClips in CFD Post and use the length expression, but that is not very clear to me, wether this is a correct or suitable approach. Has anybody done this before ? Thank you your help! Daniel |
Rep Power: 143 ![]() ![]() ![]() ![]() |
If you define an isosurface of volume fraction you can get the volume which has gone to vapour. But you will need to define how you want to convert that volume to a length - possible approaches could be maximum extent in x, y z, or a specific direction; longest extent; cube root of the volume - or maybe some other definition is suitable for your case.
Daniel
Thank you, Glenn!
Indeed it worked with the Volume Fraction. I created a polyline on the hub and shroud (later additional lines from hub to shroud) and plotted the "Curve Length" of that polyline and calcualted the length where the volume fraction is greater than zero. |
Question about the characteristic length calculation | Anna Tian | Main CFD Forum | 12 | August 2, 2019 05:47 |
Does Nu number calculation changes according to Gz number for each point of length? | Shomaz ul Haq | CFX | 7 | June 22, 2017 10:18 |
Skewness , Minimum Edge Length and Mesh Quality in FLuent | ViLaks | FLUENT | 2 | March 2, 2017 05:57 |
calculation of eddy length scale | nathalie | FLUENT | 0 | February 2, 2009 12:05 |
DPM: Particle Tracking | Madhukar | FLUENT | 1 | July 24, 2007 03:51 |
