how to use ICEM CFD mesh in CFX
Old   October 12, 2007, 07:38
Default how to use ICEM CFD mesh in CFX
MareK
Hi!
I made extruded 2D mesh in ICEM CFD 10.0 and I would like to use it in CFX 10.0. But I can't set boundary conditions in CFX-pre because I can't pick any surface (just complete mesh). So, what I did wrong or how can I define boundary conditions in CFX-pre.
Best regards, MareK
Old   October 12, 2007, 07:42
Default Re: how to use ICEM CFD mesh in CFX
MareK
Sorry, I forget to say that I made *.gtm file with ICEM CFD.
Have a nice day!
Old   October 12, 2007, 07:44
Chirag
What I understand is, you had a 2D mesh which you extruded & had a 3D mesh. Ok, redo this again in ICEM. But, this time do not forget to give different names to side walls & end wall which will be generated as result of extrusion. This things are there in "Extrude" command box only.
Best luck, Chirag
Old   October 12, 2007, 07:46
Chirag
No GTM, export only .msh file from ICEM & import it in CFX-Pre.
Old   October 12, 2007, 08:19
MareK
Thanks Chirag for response. I have C-form mesh around airfoil and I tried what you recommended. In this case inlet, top, bottom and outlet are connected and also wing is defined as top part. So how can I get each surface separated.
Thanks one more time!
Old   October 13, 2007, 03:37
Sans
Either you can take back the model to a CAD package and get it splited, or try using the various options within the surfaces tab. You can create curves and split the surfaces.
Old   October 14, 2007, 23:54
Chirag
Very true, Sans is right. If you have single surface for many objects as you said, then split it. You can either go back to CAD modeler or do it using ICEM's Boolean operations.
Best luck, Chirag
Old   October 15, 2007, 00:06
Chirag
Hold on... If you have many different parts those you want to later identify in CFX-Pre, then probably mesh extrusion will not give you the mesh required. Remember, a mesh extrusion will give you 3D mesh where you will be able to have only three different surfaces those can be later identified in CFX-Pre. You got to go for some other technique, like tetra/hexa meshing. So, explore other options.
Best luck, Chirag
Old   October 15, 2007, 10:43
Diz
Extrude your mesh and give different names to the front, back and side walls.
Next hide front and back surfaces, leaving only side wall (extruded). Click on Parts in manager and Create new part, name it something like 'Inlet' and rectange-select some region of the side wall to be in this part. Create other parts same way - 'Outlet', 'PipeWall', etc.
Save file to .msh and you will get correct regions in CFX-Pre.
mesh from icem cfd to cfx, how? Rogerio Fernandes Brito CFX 17 April 18, 2016 03:34
How to export 2-D mesh from ICEM CFD for CFX karimakhtar ANSYS Meshing & Geometry 13 November 3, 2011 09:36
[ICEM] icem mesh to CFX 12.1 atturh ANSYS Meshing & Geometry 6 February 24, 2011 14:33
ICEM 12 CFD help creating volume mesh from stl EmpError ANSYS 0 November 13, 2010 06:38
prob while exporting icem cfd hexa mesh to fluent mani CFX 4 March 7, 2007 03:41
