low utilization of RAM
Old   October 17, 2007, 04:01
Default low utilization of RAM
Toralf
FYI: CFX11, OS WXP64, CPU XEON DUAL CORE 3Ghz, Nodes appr. 1.4 million
I am happy about my 16 GB RAM, but the use in progress at Memory allocation factor 1 is only at 25 % (info from Everest, Lavalys Inc.). The virtual memory is similar. If I put the Memory alloc. factor on 10 (serial in Solver Manager) the RAM-use is only at 90 %. Of course I prefer the full use of my RAM. Please, can give somebody any advice? Gives it more possibilities to adjust the memory use? How can I predict the alloc. factor before? The virtual memory raises with the RAM-use. But I thought, if the RAM is at 100% and more then the virtual memory will grow. Thank you very much, Toralf
Old   October 17, 2007, 18:34
Default Re: low utilization of RAM
Why allocate more memory than the simulation needs? It is rare to need to adjust the memory settings in CFX. You will not get a significant performance increase. Just leave the settings at the defaults.
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 19:00
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Increasing RAM decreases CPU time!!! Melih GULEREN FLUENT 2 April 5, 2004 06:21
Can FLUENT run under Linux with 2 Gb of RAM? Paul Gregory FLUENT 0 February 13, 2001 20:10
CFD code for very low Re Flow Raj Main CFD Forum 2 May 31, 1999 22:06
