November 4, 2010, 03:41 |
CEL problem
playmaster
Rep Power: 15 |
Hello all
I have simulated a stage of turbine, considering rotor-stator interaction in ANSYS CFX. I wanna determine total pressure loss contours in a constant streamwise location surface. Can anybody help me to define the required CEL? The CEL should be defined in Pre- or Post-processor? Thanks |
November 4, 2010, 05:27 |
Rep Power: 143 |
If the simulation is complete than the post processor. Have a look at the tutorials for hints on post processing. Also check out the turbo machinery post-processing tutorial example, it should give you some hints.
November 5, 2010, 09:59 |
playmaster
Rep Power: 15 |
Thanks ghorrocks
Actually I have problem in defining of this kind of loss per each point of grid. Another problem is how to define vortex in these points. |
November 5, 2010, 15:22 |
Rep Power: 143 |
You can define a variable in CFD-Post as Initial total pressure - local total pressure and that will give you the total pressure loss. Is this what you are looking for? Do the CFD-Post tutorials for advice on how to set up variables in CFD-Post.
CFD-Post also has some vortex detection gizmos, again look at the tutorials. |
November 11, 2010, 02:59 |
playmaster
Rep Power: 15 |
Dear ghorrocks
After studing the tutorials, although I couldn't resolve my problem, but what you said gave me an insight to find the answer. Thanks a lot |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
