How to simulate a closed two phase stirring vessel
Old   November 8, 2007, 11:03
Default How to simulate a closed two phase stirring vessel
Jo
Hello everybody,
I want to simulate a closed stirring vessel containing homogenous gas and liquid phases. The problem is steady state with the vessels walls defined as rotating walls. The domain contains an inlet BC perpendicular to the rotational axis in order to get the simulation started.
When using pressure inlet or opening boundary conditions in/outflow through the BC occurs and the circumferential velocity of the gas phase becomes ten times the maximum circumferential velocity of the rotating walls.
Does anybody know how to define a two phase problem in a closed domain?
Thanks in advance
Jo
Old   November 12, 2007, 16:29
Default Re: How to simulate a closed two phase stirring ve
vm.ru
Same as in open domain. However you have to be careful. I had a similar request to service some month ago. They state that this specific case works as quasi transient only.
simulation two phase closed thermosyphon mohammad reza FLUENT 3 November 1, 2016 03:58
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
Gas filling in closed vessel chanfire CFX 3 February 16, 2010 17:23
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Ask help:How to simulate isothermal phase change? zb FLUENT 0 May 8, 2002 12:02
