ICEM CFD-- ic engine combustion chamber meshing |
November 12, 2007, 05:53 |
hi, its been a 3 months i'm trying to mesh the bowl in piston combustion chamber of ic engine.. the geometry consists of inlet valve, cylinder wall and offset piston bowl and.. its a moving and deforming mesh problem. the clearance volume between cylinder head and piston is 1.5 mm and it can also be increased till 5mm.i got the initial mesh but it is having very less quality ( 4 percent and orthogonality angle of 1.2 deg.) so, can u plz tell me if its possible to have good quality mesh for this geometry in ICEM CFD or is there any other approch to mesh it. i want the mesh to deform from top dead center to bottom dead center i.e. from clearnce volume of 1.5mm to 117.5 mm. i'll very grateful for your suggestion.. thank u be happy regards chetan M.
November 12, 2007, 16:26 |
Re: ICEM CFD-- ic engine combustion chamber meshin
It is always possible to improve mesh quality. For the expanding part of the mesh make sure you only use extruded elements (hex and prisms) as tets and pyramids have terrible quality when stretched and squished. You may wish to look at my PhD thesis on IC engine modelling: <A HREF="http://hdl.handle.net/2100/248</A">http://hdl.handle.net/2100/248</A>. Glenn Horrocks |
November 12, 2007, 16:28 |
December 23, 2007, 07:44 |
Hi I want to see the modelling of an I C Engine
January 6, 2008, 17:27 |
April 21, 2012, 02:06 |
Manjunath
hi chetan can you send me your engine model for referance to my work.
thank you |
April 21, 2012, 07:17 |
Rep Power: 143 |
This thread is 5 years old so I doubt Chetan is around any more. But some silly people like me are still around
Have a look at my thesis (the link is above), or use the new IC engine template in Workbench V14. It uses Fluent as the CFD code but has much of the setup in a template so would be by far the easiest way to set things up. |
April 23, 2012, 00:27 |
tutorial
Manjunath
hi ghorrocks, can you please provide me the fluent tutorials for ic engine, so that it might easy for me to do my work. my email is mnmudhol@rediffmail.com
April 23, 2012, 00:52 |
Rep Power: 143 |
Look in the ANSYS Workbench help/tutorials. It is there. (You will need an ANSYS community log in)
April 23, 2012, 02:28 |
tutorial
Manjunath
hi ghorrocks i am using cracked version of ansys so its not possible for me to register in the community so i request you to help me, if you are member of ansys community.
thank you |
April 23, 2012, 08:13 |
#11 |
Rep Power: 143 |
Well, you get what you pay for, don't you?
Honestly, why bother with cracked software? ANSYS has student versions available at little cost. And I think you can get access to the site from that. Alternately for students you can get access through your university's license. |
April 23, 2012, 16:19 |
#12 |
Manjunath
ya. you are right. thanks for your valuable suggestion. now i can access using my college license.
April 24, 2012, 14:54 |
ic engine template
#13 |
Manjunath
hi horrocks,
again i am unable to get ic engine template in the ansys workbench tutorial. so can you please download it and send me. please its very urgent for me. waiting for your positive reply. thanking you |
April 25, 2012, 07:46 |
#14 |
Rep Power: 143 |
Sorry, I do not down load stuff for people. Have a look on the community site under tutorials. It is there. Note it is a tutorial for ANSYS V14.
July 22, 2012, 09:19 |
#15 |
Hi ghorrocks,
Please can you tell me if I can use Fluent v.14 to move base of the cylinder for exmaple without UDF ( my geometry is Heart Pump and it is similar to the piston and I want to move the pusher plate) can use option(in-cylinder) if u can help me with some tutorial about that. Regards Mohammed |
July 22, 2012, 18:34 |
#16 |
Rep Power: 143 |
Best ask on the fluent forum then.
[ICEM] Having several dificulties with 3d airfoil meshing in ICEM CFD | Teja | ANSYS Meshing & Geometry | 14 | February 23, 2015 13:01 |
Wind tunnel hexa meshing in ICEM CFD 12.1 | matheusguzella | ANSYS Meshing & Geometry | 1 | March 14, 2011 16:14 |
Icem CFD Meshing Problem | eRzBeNgEl | ANSYS | 1 | January 20, 2011 07:55 |
pipe flow- meshing in ICEM CFD? | Nikhil | CFX | 2 | February 29, 2008 06:14 |
ICEM CFD 2D meshing guide for CFX (1cell height) | Korsh Mik | CFX | 1 | October 27, 2005 22:45 |
