Hydrogen Leak Simulation Issue In CFX
Like Tree5Likes
  • 3 Post By Gert-Jan
  • 2 Post By ghorrocks
Old   March 1, 2023, 06:46
Post Hydrogen Leak Simulation Issue In CFX
Arjun
arjun71 is on a distinguished road
I put my pipe in a cylinder-shaped enclosure to figure out how hot the leak was.
My enclosure (opening) contains 21% O2 and 79% N2.
I set up my leak zone as an inlet for hydrogen. I tried different types of mass flow rates in my hydrogen inlet, and the simulation is running well, but the temperature is not changing in my enclosure.
What should I do now?
arjun71 is offline   Reply With Quote
Old   March 1, 2023, 09:52
Gert-Jan
Gert-Jan will become famous soon enough
What do you expect? Cooling as a resullt of expansion? Then turn on Total Energy.
Gert-Jan is offline   Reply With Quote
Old   March 2, 2023, 04:03
Arjun
Generally, we know that hydrogen increases temperature when it flow through a leak (the Joule-Thomson effect).
My leak's temperature is not changing from 25 degrees C.
If the temperature does not increase, my result will be worthless.
Old   March 2, 2023, 04:08
Gert-Jan
Then it should indeed incease in temperature. So, are you running with Total Energy?
If it does not work, I have no idea. No specific experience with hydrogen......
Old   March 2, 2023, 04:18
Arjun
How can I turn on total energy ?
because I am a beginner in Ansys World.
Old   March 2, 2023, 04:33
Gert-Jan
ANSYS CFX is not a kind of Chat GPT in which you throw some stuff from a distance and then get an outcome that fits you well.
Therefore you should first do several tutorials on thermal problems and them come back here.
karachun, zacko and AtoHM like this.
Old   March 2, 2023, 17:18
The Joule-Thomson effect is a real gas effect. You cannot model this with ideal gases, so you are going to have to use a real gas model. So this is more complex than "just" a compressible flow simulation, it is real gas compressible flow simulation, probably with a high pressure ratio and high Mach numbers. This is a complex model which will require careful development, and does not sound like a simulation for a beginner to attempt.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 5, 2023, 02:39
Arjun
I run with total energy, but there has been no change in temperature.
Moreover, I am using real gas. It's also the same.
According to the Letaure evaluation, I must use N2 and O2 at STP.
I tried this one, too, with high pressure and a high Mach number.
In every method, there was still no temperature change. But velocity is showing good results.
Old   March 5, 2023, 03:13
If you are going to try to attempt this complex model then you need to approach it as you would approach any complex model. You need to start with a simple model and add the complex physics one step at a time (or preferably in a series of separate simulations) before doing the final simulation with all the physics you need, and hopefully giving you something close to the correct answer.
I would start with an ideal gas and a simple geometry where it goes through a nozzle. Make sure the pressure difference does not generate supersonic flow (so stay subsonic). Once you have this working, then add the hydrogen real gas. Then model the crack as ideal gas at the actual pressure ratio, before finally modelling the crack at full pressure with hydrogen real gas.
You need to get all the physics sub-models working by themselves before you combine them together. If you run it with everything and it fails, how do you know where the problem is?
karachun and hogsonik like this.
Old   April 3, 2023, 22:30
Arjun
Thank You.I solved my previous problem.
Now,how can i set external ignition on cfx ?
because experiment has an external ignition.
Old   April 3, 2023, 22:58
Have a look at the spark ignition model, Theory manual section 7.15.
Old   April 4, 2023, 07:56
Opaque will become famous soon enough
How did you solve it? The forum is a two-way street, and everyone benefits from everyone's else experiences.
Opaque is offline   Reply With Quote
Old   April 4, 2023, 20:48
Arjun
I set total thermal energy and made my air domain bigger ,then it works well.
Old   April 5, 2023, 08:52
Thank you for the feedback.
Sure you mean "Total Energy" since it cannot be both because Total Energy = Thermal Energy + Kinetic Energy
Simulation results of cfx and fluent are different. dhehdxhdaus FLUENT 1 August 10, 2022 02:20
My multi-step combustion simulation in CFX doesnt work out for steady state Xun CFX 10 November 25, 2021 13:26
Wind Tunnel Flow Simulation Mass Flow BC Issue ledelman SU2 4 August 3, 2014 18:38
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 09:32
another issue about HPC cluster for running cfx, hepl PLZ. happy CFX 4 March 4, 2012 23:58
