2D models in CFX
Old   November 21, 2007, 17:36
Default 2D models in CFX
Igor M.
Hi. Here is my problem:
I'm trying to simulate 2d heat tranfering by natural convection. I'm afraid that CFX doesn't support 2D models. But documentation said:
"2D Meshes are not supported in ANSYS CFX. However, ANSYS CFX can use 3D meshes that are one element thick"
It also said nothing about what the best ELEMENT THICK. Changing element thick cause sufficient changing velocity field.
Can anyone halp with such problem? What is th best element shape and size?
Thanks Igor M.
Old   November 23, 2007, 14:35
Default Re: 2D models in CFX
Zoran
Hi Igor,
can you describe your geometry, the thermal boundary conditions and the goal of your simulation. Maybe I can help you.
Regards, Zoran
Old   November 24, 2007, 03:08
Jia
If you choose symmetry boundary condition at the two faces vertical with the thick direction, I think there may be no difference with the element thick. Good Luck!
Jia
Old   November 24, 2007, 15:41
Mohammad Faridul Alam
Use 'Extrude 2D Mesh' under 'Options' in CFX mesh and select 1 layer.
Old   November 25, 2007, 09:10
Igor M.
Hi, Zoran.
I'm trying to investigate cooling effect of natural convection by CFX with expremental verification. The fist iteration is to make simple model with follows geomentry:
ssssssssssss s s s s s s H s H s H s s s s s ssssssssssss
where H is heat source with temp = 310. and s is the boundary with no slip condition.
What is the bet way. I'm intersting in stationary solution.
Thanks. Igor.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX vs. FLUENT in multiphase models Hossam CFX 1 November 3, 2010 06:57
Modelling Bingham in CFX 11.0 Dirk CFX 6 March 12, 2009 07:42
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
