Static Pressure & Hydrostatic Pressure
Old   March 7, 2004, 20:56
Default Static Pressure & Hydrostatic Pressure
Liwau
Dear all,
What's the difference between Static (Thermodynamic) Pressure and Hydrostatic Pressure? Any example or some equations to show the difference?
Your any answer will be highly appreciated.
Liwau
Old   March 9, 2004, 03:17
Default Re: Static Pressure & Hydrostatic Pressure
Vistor
Helloo,, I'm not an experince person, however I think the hydrostatic pressure is related to stationary liduid whereas the static is dealing with gases in closed container. I may be wrong! Let's hear from the rest
Old   March 9, 2004, 18:05
Hi Liwau,
Static pressure is the pressure of the fluid at that point. Total pressure is static pressure plus the dynamic head (0.5*density*V^2), and represents the static pressure which would result if a moving fluid was brought to rest with no losses - the pressure would increase due to Bernoulli. Hydrostatic pressure is the pressure in a fluid due to the weight of fluid above it, for instance air pressure is a result of the weight of air in the atmosphere above you.
In CFX, static and total pressures are available in CFX-Post. Hydrostatic pressure is only applicable when you have defined a gravity vector, and this is usually for a natural convection simulation.
Regards, Glenn
Old   April 16, 2023, 12:32
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
Static pressure refers to the pressure exerted by a fluid on a solid surface that is in contact with it. It is a measure of the force per unit area acting perpendicular to the surface. In contrast, hydrostatic pressure is the pressure exerted by a fluid on a submerged object, due to the weight of the fluid above it. It is a measure of the force per unit area acting in all directions at a given depth in a fluid. Hydrostatic pressure is a result of the weight of the fluid acting on an object submerged in the fluid, while static pressure is a result of the fluid pushing on a solid surface.
Mahmoud Abbaszadeh is offline   Reply With Quote
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
Static pressure problem Kiat110616 CFX 0 April 12, 2011 13:11
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
negative static pressure Selo melo FLUENT 5 December 18, 2006 09:30
