Streamlines in -z direction
Old   December 10, 2007, 13:16
Default Streamlines in -z direction
Surfinggirl
Hello together!
I want to plot streamlines in cfx post, starting from a plane in the direction of -z (and not in +z, which is set as default). How can I change the direction of my streamlines?
Thank you!!!
Old   December 10, 2007, 16:14
Default Re: Streamlines in -z direction
The +/- direction of the normal vector of a plane to seed streamlines is irrelevant. To change the direction of the streamlines choose either upstream or downstream on the streamlines tab.
Old   December 11, 2007, 13:53
jakjak
Adding to Glenn's comment, I think the option that you're looking for is the direction: - Forward: Downstream of the plane - Backward: Upstream of the plane - Forward and backward: Both downstream and upstream
Flow Direction: normal to boundary!!! Atit CFX 1 August 2, 2015 13:42
[ICEM] Changing edge direction la7low ANSYS Meshing & Geometry 2 June 7, 2010 13:26
Streamlines under Moving reference frame; Spiral streamline from Tecplot aiqch Tecplot 2 October 29, 2009 23:27
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
STAR-CD, moving grid and streamlines Mohamed GUEROUACHE Main CFD Forum 1 September 13, 1999 13:33
