Total pressure in rel frame and total pressure |
March 12, 2012, 08:45 |
Rep Power: 14 |
Hi! Please let me know what is a principal difference between Total pressure in rel frame and Total Pressure functions in a case of axial turbine stage problem. CFX Post returns different fields of theese variables on turbo surface with constant span =0.5, but i think they must be identical. Thanks.
March 12, 2012, 16:25 |
Rep Power: 143 |
Total pressure = p + 1/2 rho v^2
The velocity term is different depending on what frame of reference you measure it in. This means total pressure is different in different frames of reference. |
March 13, 2012, 08:53 |
Rep Power: 14 |
Thanks, ghorrocks. I was made a mistake in my question, in fact I told about only rotating domain. The velocity term on the rotating frame of reference is the same for total pressure and total pressure in rel frame, isn't it? So why do the total pressure and total pressure in rel frame fields for look different in a same rotating domain?
March 13, 2012, 16:31 |
Rep Power: 143 |
My previous post explains why. Because the velocity in the two frames of reference is different.
March 14, 2012, 03:35 |
Rep Power: 14 |
Ok, probably it's my english problems.
I ask you directly: What is the differnce between: Total Pressure in Stn Frame=p+1/2*rho*Ustn^2 (1) Total Pressure in Rel Frame=p+1/2*rho*Urel^2 (2) Total Pressure = p+1/2*rho*(Urel^2-(omega*R)^2) (3) I know, that Urel=Ustn-omega*R in rotating systems, Physical meaning of 1 term - absolute total pressure Physical meaning of 2 term - relative total pressure But what's the physical meaning of term 3 ????!!!! Best wishes! |
March 14, 2012, 05:09 |
Rep Power: 143 |
Eqn 3 is not total pressure. It is rothalpy. Look it up in the documentation (eqn 1-56 in the theory guide) or on google.
December 1, 2014, 05:11 |
#7 | |
saleh
Rep Power: 11 |
Total pressure in rotating frame is less than static pressure (In the outlet ), whereas according to equation: Total Pressure in Rel Frame=p+1/2*rho*Urel^2, it should be greater than static pressure because of positive values of "1/2*rho*Urel^2" in any condition(rotating or stationary frame) . My test case is NASA rotor37. What is the reason for this contradiction? Another question: Urel=Ustn-omega*R and Ptotal(rot)=pstatic+1/2*rho*Urel^2, as aresult: Ptotal(rot)=pstatic+1/2*rho*(Ustn-omega*R)^2 but in cfx theory guide(equation 1-53): Ptot(rot)=Pstatic+1/2*rho*(Urel*Urel-(omega*R.omega*R)). What is the reason for this contradiction? |
December 1, 2014, 16:07 |
Rep Power: 143 |
Are you saying you are getting total pressure in a rotating frame less than inlet static pressure in your case? Can you post an image of what you are modelling? And the boundary conditions?
December 2, 2014, 03:38 |
#9 |
saleh
Rep Power: 11 |
Yes, In CFD-Post, 3 Total pressure is exist: Total Pressure, Total pressure in Rel Frame and Total Pressure in stn Frame. Total pressure is less than static pressure but total pressure in rel frame and total pressure in stn frame is greater than static pressure. Image of Mach contour in 80% span is attached. Boundary condition:
Test case: NASA ROTOR 37 Reference pressure:0 [pa] Inlet: Total pressure:1[atm] Outlet: Static pressure:106.5 [kpa] Angular velocity:-1800[rad/s] High resolution discretization is used for all equations. High speed numeric, clip pressure and high resolution rhio chow algorithm are activated via advance parameter tab in solution tab. I can not reach to nominal mass flow rate (20.19 kg/s) and total pressure ratio (2.1) by variation in static pressure. I reached to pressure ratio 1.88 and mass flow rate 20.38 at best condition. What is its solution? |
October 6, 2015, 04:26 |
#10 |
Hi guys,
I was reading the forum and have still a question regarding the total pressure in rotating frame. I could reproduce the values for "TotalPressure in relative and stationary frame" with the given formulas. But for the TotalPressure itself I didnt get the value in [Pa] as CFX gives me, I get to high values. Total Pressure in Stn Frame=p_stat+1/2*rho*Ustn^2 OK Total Pressure in Rel Frame=p_stat+1/2*rho*Urel^2 OK Total Pressure = p_stat+1/2*rho*(Urel^2-(omega*R)^2) Fail For R I use the maxValue at the plane I want to investigate. Would be nice if someone could give me some advice. Thanks |
February 19, 2016, 20:38 |
Rothalpy shows the loss without output work
#11 | |
Liu Meng
Difference between total pressure, total pressure in Stn and in Rel frames Anyhow, if you understand what rothalpy is, these three definitions of "total pressure" should not be a problem. The definiton of Total Pressure here, which is used in CFD-Post, is deduced from rothalpy. It gets rid off the work which the fluid output against the rotors. The work will be computed differently in the stationary frame and rotational frame. If the stationary work is added to rothalpy, the result is the total enthalpy in stationary frame. And the difference between rothalpy and the total enthalpy in relative frame showes the effect of Coriolis force. The equation of rothalpy includes a part that (Omega X Radius)^2 should be taken away. So if the calculation is about rotors, and the output work is very large, it is quite possible that the rothalpy is negative, or the total pressure is less than the static pressure. I think this Total Pressure definition based on rothalpy can be very convenient for loss assessment, especially for the centrifugal pump or radial flow turbine. For these flowfields, the Omega X Radius may be quite different on the same streamline within a rotational domain. Last edited by sodynamic; February 19, 2016 at 23:53. |
February 20, 2016, 09:09 |
#12 |
Rep Power: 16 |
May 3, 2023, 16:28 |
#13 |
Pushkar Dev
what is stat frame total pressure and static pressure? what is the difference between these pressure?
May 3, 2023, 18:14 |
#14 |
Rep Power: 32 |
There are all kinds of qualifiers for Pressure, and the context must be given. The most common are:
1 - Absolute Pressure: let us call this one the baseline thermodynamic pressure 2 - Gauge/Manometric Pressure: it means it is a reference to a fixed value, usually atmospheric. --> Absolute Pressure = Gauge/Manometric Pressure + Reference Pressure 3 - Static Pressure: the pressure measured when the fluid is NOT in motion 4 - Dynamic Pressure: the pressure measured when the fluid is in motion 5 - Stagnation/Total Pressure: it is the equivalent static pressure if the fluid is decelerated isentropically to rest. It can be represented in Absolute terms or Gauge/Manometric terms; therefore, context is important 6 - Stationary/Relative Frame Stagnation/Total Pressure: is the Total Pressure in the specified frame of reference. The stationary qualifier is used whenever there is a moving reference frame and there is a need to differentiate between them. Stagnation/Total Pressure includes a kinetic energy contribution which can be a relative frame or stationary frame velocity; therefore the distinct naming. So, you could be very explicit and use all qualifiers Stationary Frame Absolute Total Pressure Ouch!!
May 8, 2023, 02:29 |
#15 |
Pushkar Dev
Thank you very much for your reply.
Total pressure in CFX | famarcfd | CFX | 0 | June 17, 2011 10:33 |
rotating frame of reference and total pressure | viking | ANSYS | 1 | November 23, 2010 23:25 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Definition of Total Pressure in rel. Frame of Ref. | Thorsten | CFX | 0 | November 30, 2006 03:33 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
