transonic rotor convergence problem
Old   January 5, 2008, 05:30
Default transonic rotor convergence problem
Noureddine
I faced same convergence problem as posted before by Samad in this forum, with an indication that the maximum Mach number increase too much.
I have used CFX-TurboGrid 11.0 for mesh generation and the Turbomachinery template for the CFX-PRE 11.00
I want to know if somebody have successful to get a convergence with a transonic compressor (rotor37 i my case)? and if yes, plz, tell how you did it ?
any other advice is welcome
Regards Noureddine
Old   January 6, 2008, 05:59
Default Re: transonic rotor convergence problem
Noureddine
even I try to simulate the off-design flow (60% of design speed = 1080 rad/s) to have a subsonic axial compressor, I found same difficulty to converge. I used P-Total Inlet Mass Flow Outlet as boundary conditions, with, Reference Pressure = 1 atm, P-total = 0 atm, Mass Flow rate per Machine = 13.9 kg/s.
what is the problem ? any help is very welcome.
Regards Noureddine
Old   January 6, 2008, 11:20
Noureddine
It's OK, i found my mistake, it was the direction of rotation !!!!, we should indicate the sign of the rotation as -1800 rad/s for the design speed.
Old   January 6, 2008, 17:23
Amir
Hi Noureddine,
Well i know you solved your problem but i have a small question. I am simulating a rotor in a stator (journal bearing) using turbomachinery template in CFX 11. I have a lubricant between my rotor and stator...When i do a transient simulation the residuals oscillating. did you have the same problem how did you solve it?
Old   January 7, 2008, 01:42
Noureddine
Hi Amir,
yes i had an oscillation of residuals in the last steps, but results was acceptable.
sorry, i have solved only the steady flow of a transonic compressor and i did not deal with the transient rotor/stator simulation.
Good luck Noureddine
Old   January 8, 2008, 07:46
pankaj
Hi Noureddine!
the negative sign is for your rotors rpm,which is not always common,it specifies the direction of rotation.
Old   January 8, 2008, 08:23
Noureddine
Hi Pankaj,
i know that's not always common, i am talking only about my own problem (own geometry) which is the axial compressor "rotor37".
you are right, it specifies the direction of rotation.
thanks for you message.
Regards. Noureddine
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
