January 11, 2008, 11:14 |
Turbulence intensity and length scale
Hi everybody
I simulate gas dispersion in atmosphere, how can I know turbulence intensity and length scale in air inlet or gas inlet? Thanks |
January 13, 2008, 17:41 |
Re: Turbulence intensity and length scale
This should be reported in the experimental results you are trying to reproduce. Glenn Horrocks |
January 14, 2008, 01:37 |
Hi It's a field experiment and I have only wind data (speed, direction) with time and height. I havent any turbulency data!
eslam |
January 14, 2008, 16:37 |
Look in the literature and find what a typical atmospheric turbulence profile would be then. Also, depending on the simulation it might not be that sensitive to the exact turbulence level so a guess is OK. This is problem dependant and needs to be checked. Glenn Horrocks |
Turbulent Length Scale and Intensity for Airfoil | shamim | STAR-CCM+ | 2 | July 12, 2017 23:11 |
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 07:22 |
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? | david39 | OpenFOAM Running, Solving & CFD | 6 | February 2, 2011 03:01 |
k-epsilon: Defining turbulent intensity and length scale? | klausb | OpenFOAM | 0 | January 23, 2011 07:28 |
