Constant pressure!
Old   January 15, 2008, 16:25
Default Constant pressure!
Mann
Can some body tell me how to fix a constant pressure within each cell of my simulation! Thanks
Mann
Old   January 15, 2008, 16:28
Default Re: Constant pressure!
You can turn the hydrodynamic solver off, this will fix the velocity and pressure fields. You do this using an expert parameter. Is this what you want?
Old   January 15, 2008, 19:06
Mann
In the paper they have imposed constant pressure gradient on every cell as a driving force, with fully periodic boundary conditions at the inlet and the outlet. So basically i want to get fixed pressure of -1.59 Pa/m within every cell of my domain before i switch to periodic BC.
I will look into expert parameter tomorrow, but i only want to fix my pressure not velocity field! If you can more precisely explain how to do that it will be very helpful!
Mann
Old   January 15, 2008, 19:32
Mann
Sorry i need to obtain a fixed pressure of 0.13 Pa within every cell of my domain because my duct in 0.08m long. If anyone can explain how to do that it will be very helpful!
Mann
Old   January 16, 2008, 04:51
It cannot be done. The pressure field is coupled to the velocity field so fixing one and allowing one to float is not physically meaningful.
I would use the translational periodic boundaries with a pressure difference. This feature exists in CFX and is more physically meaningful.
Old   January 16, 2008, 07:30
Usman
Ok makes sense! Thank you Glenn
Old   January 16, 2008, 07:34
Usman
One more thing if i specify pressure change in Interface domain, do i need to specify initial velocity in domain initialistaion or global intialistaion.
Usman
Old   January 16, 2008, 17:09
A sensible initial guess will improve convergence and is always a good idea.
How to calculate Cp (Heat Capacity at Constant Pressure) ? Gian Maria OpenFOAM Programming & Development 5 November 10, 2021 11:53
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Abt 'a constant pressure boundary condition' jinwon park Main CFD Forum 3 April 7, 2008 19:36
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
