Pressure Gradient!
Old   January 15, 2008, 13:14
Default Pressure Gradient!
Usman
Hi guys
How can i specify constant pressure gradient in my LES simulation. In paper they have used -1.59 Pa/m as a constant pressure gradient. How can i use that value as my pressure in CFX? Thanks
Old   January 15, 2008, 16:29
Default Re: Pressure Gradient!
Isn't the pressure gradient a result of the simulation or experiment, not an input to it?
Old   January 16, 2008, 03:30
Johnson
Are you modelling a section of pipe or channel? If this is the case you can either:
1. Use a subdomain momentum source in the flow direction to drive the flow, which gives the desired dP/L.
2. Use a periodic domain interface with the Pressure Change option. The gradient is then (specified pressure change)/(Length of domain).
Johnson
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
Inputting pressure gradient in Fluent Josyula FLUENT 2 December 23, 2009 07:26
Atmospheric pressure gradient Luc3er FLUENT 1 October 30, 2009 06:46
Hydrostatic pressure gradient Craig Finch (Finch) OpenFOAM Running, Solving & CFD 10 February 28, 2007 23:02
Flat plate with pressure gradient Sheila Main CFD Forum 3 September 24, 2005 13:58
