Bladegen Data Import wizard hub surface problem |
June 14, 2023, 08:02 |
babagiray
Hey everyone,
I am working on turbine blade optimization for a specific flow rate. I have the CAD design of the turbine runner attached below(1), but I wanted to convert it into the bladegen by using the data import wizard. I attached the steps that I have taken in the data import wizard, I selected hub and shroud curves and the meridional profile is created. (No problem until here). However, as you see in picture 7, I want to have the hub surface as a flat surface as depicted in the picture's red lines without any changes in the blade shape. I mean everything is correct except the flow path starting point. It should be perpendicular to the blades. Do you have any suggestions on how to do it? 1) https://ibb.co/gzjtKGv 2) https://ibb.co/RSSRHJF 3) https://ibb.co/yXXtzFz 4) https://ibb.co/QMNTD04 5) https://ibb.co/LSTWZF8 6) https://ibb.co/G25dsFM 7) https://ibb.co/wpL0J81 Thank you Mustafa |
June 16, 2023, 03:38 |
Daniel
Rep Power: 9 |
You can also attach images directly into your post. Makes things easier and we don't have problems in the future, that the link expires or so.
June 21, 2023, 03:34 |
Daniel
Rep Power: 9 |
It seems that your meridional profile is not correct at the hub.
If you want to have a straight hub like in Image 1, you need to draw a straight line in your meridional profile. |
bladegen, data import wizard |
Error in gmshToFoam on ESI v2106 | siefer92 | OpenFOAM Programming & Development | 4 | July 17, 2021 05:11 |
[BladeModeler] BladeGen Data Import Wizard | Turbofan | ANSYS Meshing & Geometry | 0 | April 16, 2020 08:22 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Problem of import fluent data to ilight fieldview | seasoul | FLUENT | 3 | September 9, 2008 22:36 |
