February 5, 2008, 04:12 |
Fatal Overflow when using RNG k-e
I am doing a study around and inside a front wheel of a car. Geometry is very complex but I succeeded to get a good mesh with prism and tri. Skewness below 0.9. I have already refined in the critical regions to obtain convergence. But I only get convergence for the k-e model. When I try to the RNG model, it stops at iteration #9 with fatal overflow although residuals seem to converge and the drag coefficient too. Physical timestep is 0.382s. Is the RNG model an appropriate model for such a complex flow? I found an old post (archive 2005) saying no but without any arguments! (It was just saying that it leads to false results with tetra mesh). Do you have any clue of how to solve this convergence problem? |
February 5, 2008, 05:39 |
Re: Fatal Overflow when using RNG k-e
Hi again.
It seems to work by dividing the physical time scale. (I divided it by 100). Wait and see now... By does anyone has an opinion about RNG on tetra mesh? Below is the link of the old post saying it was not appropriated. http://www.cfd-online.com/Forum/cfx_....cgi/read/9731 Thanks! |
February 5, 2008, 16:41 |
In my experience the RNG model is very similar to the k-e model for results and stability. I know of no reason why RNG should be inherently less stable than k-e for tet grids. I think you have found the key, use a smaller timestep when starting up and ramp the timestep up as the simulation progresses. Glenn Horrocks |
Solution variables goes outside upper limit -how to localize fatal overflow occurance | Dimone | CFX | 2 | January 21, 2011 06:35 |
desperate Fatal overflow in linear solver - transient | kingjewel1 | CFX | 9 | January 5, 2010 13:53 |
Fatal overflow in multiphase | Jason | CFX | 2 | July 3, 2006 04:30 |
fatal overflow!!! | prayskyer | CFX | 0 | June 7, 2006 22:28 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
