characteristics curve generation with opening type boundary?
Old   July 26, 2023, 06:00
Default characteristics curve generation with opening type boundary?
Bhanu Swaroop Madiraju
Bhanu Swaroop is on a distinguished road
I have a basic question. I am running a simulation for a compressor. There was flow recirculation at the volute outlet as suggested I used an opening-type boundary with opening pressure and temperature. Opening pressure condition has static pressure outflow and total pressure in flow. So if I want to generate a performance map, we usually do it by gradually varying the static pressure at the exit. So is it the same with opening type boundary too? Can we decrease the opening pressure to generate the curve? (I do know the best practice is to extrude the domain at the outlet to not involve an opening type boundary but I just wanted to know if the above method with the opening I described is also correct or not)
Bhanu Swaroop is offline   Reply With Quote
Old   July 26, 2023, 12:07
Opaque will become famous soon enough
Though I am not addressing your specific question, may I ask why you are using a pressure boundary at the outlet when you could use an Exit Corrected Mass Flow boundary instead?
With pressure boundaries, you can into trouble quickly depending on how smooth your compressor performance curve is.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   July 26, 2023, 12:18
I don't think there's an option to give mass flows as boundary condition for an opening type boundary. There's opening pressure, static pressure, entrainment etc
Old   July 26, 2023, 12:53
For a mass flow exit condition, you will never have artificial walls; therefore, never a need for an opening --> OUTLET
Old   July 26, 2023, 13:44
Oh I didn't know this, thanks for this info. But the exit corrected mass flow boundary can only be used for ideal gases (My case is for a real gas).
Old   July 26, 2023, 14:21
I understand the use case for real gas is a beta feature. Hopefully, you will get a message in the output file.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Error during initialization of "rhoSimpleFoam" kornickel OpenFOAM Running, Solving & CFD 8 September 17, 2013 05:37
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
