Fourier Transformation with Harmonic Balance
Old   August 3, 2023, 11:36
Default Fourier Transformation with Harmonic Balance
Deutschland
Sebastian Maier is on a distinguished road
Hey guys,
currently i am working on a transient rotor stator problem. in my model, consisting of inlet channel - rotor - stator - outlet channel, i have already simulated a Fourier transform with time integration. this has worked so far and the results agree well with those of a steady state reference simulation. Now i want to try a harmonic balance as transient method instead of time integration. for this i have defined the interfaces between inlet and rotor as well as stator and outlet as frozen rotor interfaces, because stage mixing plane is not viable. However I get some warnings and an error message before the simulation even starts. i will post this message below:
| ****** WARNING ****** |
| This Transient Blade Row run may experience robustness and/or |
| convergence difficulties caused by the "Frozen Rotor" domain |
| interface : IF1 |
| which could inject additional frequencies not captured by the |
| defined Fourier transformations. |
Details of error:-
Error detected by routine PEEKCA
CDANAM = CPERIOD
CRESLT = NONE
Current Directory : /ABR/OUTPUT/ZN1
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
Does anyone have an idea what the problem could be here?
PS: I have already asked a short question about this, where I thought that the problem is solved so far, but it did not quite work. someone said the periodic boundarys could be the reason but i checked them and found nothing suspicious, especially since there were no issues with it before.
Best Regards,
Sebastian
Sebastian Maier is offline   Reply With Quote
Harmonic balance method for calculating multi-stage turbines HIT19B902072 SU2 2 April 24, 2022 01:31
Post-processing for Transient Blade Row: RotorStator FOURIER TRANSFORMATION M-B CFX 0 June 29, 2017 09:17
Problems with CFX Fourier Transformation Falcon16 CFX 0 October 16, 2016 15:06
Transient Blade Models - Fourier Transformation - Transient Rotor Stator Veronique Pe CFX 11 October 22, 2014 04:44
TBR Fourier Transformation Method Eschek CFX 2 May 16, 2013 16:12
