March 29, 2016, 04:11 |
Internal combustion engine simulation
Hi all,
just looking to see if I can get some help with a current simulation I am working on. I am using CFX to model the intake stroke of an internal combustion engine to analyse the effectiveness of an intake port(currently without the valve geometry for simplicity). So far i have managed to apply the mesh motion technique and the simulation runs until the piston is approximately 75 deg ATDC. At this point i encounter the error of negative volume and highly skewed mesh causing the solver to crash. I have kept the geometry and mesh quite basic as firstly i would like to learn the process and setup and then further refine the geometry and mesh. I have applied a pressure inlet at the intake of the port, and used a wall boundary with "parallel to boundary" mesh motion on the piston/cylinder walls. On the top of the piston I have applied a wall boundary with "specified displacement" mesh motion, where the motion of the piston is defined by an expression named "pistondisp" which relates the displacement of the piston to time, which is determined by the time step in the simulation. I have attached some images which i hope will help with my explanation. Any suggestion would be greatly appreciated. Port_and_Chamber_TDC.JPG Port_and_Chamber_MidStrokeJPG.JPG Mesh.JPG setup2.JPG setup1.JPG |
March 29, 2016, 20:08 |
Rep Power: 143 |
This FAQ has tips and how to debug this problem: http://www.cfd-online.com/Wiki/Ansys..._went_wrong.3F
By the way: my PhD thesis used CFX to model internal combustion engines https://opus.lib.uts.edu.au/handle/10453/20133 |
August 12, 2023, 17:54 |
Using CFX to simuate IC engines
Saeed Pashazanousi
Rep Power: 6 |
Hi Ghorrocks, I was wondering if you could send your Ph.D. thesis to me (st_s.pashazanousi@urmia.ac.ir). I want to simulate a rotary engine in CFX.
Thanks for your kindness and generosity
Best regards Saeed Pashazanousi Urmia University Email: st_s.pashazanousi@urmia.ac.ir |
August 12, 2023, 21:43 |
Rep Power: 143 |
The link I posted 7 years ago is still valid. You can download it from there.
August 13, 2023, 03:55 |
Saeed Pashazanousi
Rep Power: 6 |
Hi Ghorrocks, Thanks for your quick reply. But the link doesn't work!
August 13, 2023, 06:03 |
Rep Power: 143 |
The link works fine for me. I just tested it.
Try another browser. Or try downloading it from another network. Maybe Australia is blocked by Iran or the other way around - in that case try a VPN.
Valve profile for an internal combustion engine | omar87st | FLUENT | 14 | April 21, 2023 05:35 |
Two-day Meeting on Internal Combustion Engine Simulations Using OpenFOAM Technology | lucchini | OpenFOAM Announcements from Other Sources | 1 | October 21, 2015 16:16 |
Modeling the air flow of an Internal Combustion Engine | mateusdias89 | CFX | 21 | September 23, 2015 08:22 |
Stratified Charge Engine Combustion Chamber Design | AdamL | OpenFOAM | 15 | January 27, 2012 20:47 |
numerical simulation of internal combustion engine | hamed | FLUENT | 0 | October 19, 2005 03:03 |
