FSI using Fortran routines
Old   February 7, 2008, 09:20
Default FSI using Fortran routines
Anders
I've been pondering the last days on how to extract the nodal forces on a wall boundary during a transient run, and use them in a fortran routine to govern the node displacements on that boundary (ie govern the FSI using Fortran code).
So far, it seems I can get the face area of all faces on the boundary, along with the normal vector to the face, and the pressure in all nodes. This of course makes it rather difficult to extract nodal forces, as the pressures are given in the nodes, where as the areas are tied the the element faces.
Can anyone give me advice on the subject, which subroutines might already be available or how to integrate the pressure in each node up to a nodal force.
Thank you in advance,
Anders
Old   February 7, 2008, 16:32
Default Re: FSI using Fortran routines
Why is the built in FSI between CFX and ANSYS not suitable?
Old   February 7, 2008, 17:08
Anders
I am not quite sure what built in features ANSYS-CFX have, as I am not an experienced user.
I need the nodal forces so I can use them in a Fortran routine to calculate the deflection of my geometry using a modal model with the significan eigenmodes.
If there is a built in function to do this, I am all ears.
- Anders
Old   February 10, 2008, 04:19
Yes, ANSYS has a built in FSI link to CFX. You will need both a CFX and an ANSYS license to use it. Talk to your CFX support if you don't have the licenses.
general introduction for customizing flow3d with fortran routines jk75 FLOW-3D 4 May 22, 2012 11:16
Fortran Compilers to write routines in CFX Luiz CFX 1 February 11, 2008 13:02
User fortran routines, DEBUG AND OUTPUT Bloshchitsyn Vladimir CFX 5 October 29, 2007 01:31
call fortran routines from UDF lily FLUENT 0 March 29, 2005 18:26
CFX 5.7: Blank fortran routines? NymphadoraTonks CFX 1 October 22, 2004 00:17
