ANSYS Workbench on "Uncertified" Linux Distros
Like Tree26Likes
Old   February 24, 2011, 09:48
Nikolopoulos Aristeidis
Nikolopoulos is on a distinguished road
There are to many!!!!
Nikolopoulos is offline   Reply With Quote
Old   February 24, 2011, 09:53
Vadim
Conakry is on a distinguished road
Originally Posted by Conakry View Post
Hi all!
I have the ArchlinuxOS x86_64, Ansys 13 and two questions...
1. Why does DM start so looong time? It`s 10 minutes approximately.
2. Why does ME crach after the looong attempt to start?
My regards!
I must claim! Ansys13 is playing fine on RHEL6 x86_64!
Conakry is offline   Reply With Quote
Old   February 24, 2011, 09:55
Vadim
Perform:
# ls /lib64/ld*
Old   February 24, 2011, 10:05
Default this code doesn't seem to do anything...
  #124
However:
/lib/ld-linux.so.2 doesnot exist
lib folder doesn't have such files.
in /lib64 there is a ld-linux-x86-64.so.2
I appreciate your help!
Old   February 24, 2011, 10:27
Vadim
However:
Enter to /lib64 and make simlink:
# ln -sf ./ld-linux-x86-64.so.2 ./ld-lsb-x86-64.so.3
After that you can repeat to run INSTALL-script.
Old   February 24, 2011, 10:36
I solved the problem
yum install glibc.i686
but now i have the same problem with libstdc++.so.6
Old   February 24, 2011, 10:45
Vadim
glibc.i686 you needn`t
You can install redhat-lsb package also instead of simlink making.
Old   February 24, 2011, 10:54
I installed redhat -lsb package but still libstdc++.so.6 is not available
Old   February 24, 2011, 11:22
Vadim
Remove glibc.i686 and try to upgrade glibc.x86_64.
Old   February 24, 2011, 11:29
i did it. but glibc.x86_64 is already installed!!!
When i remove glibc.i686 the problem with ld-linux.so.2 occurs again
Old   February 24, 2011, 11:38
Vadim
So, you need make simlink (see my previous post about it).
Also you could need to make such simlink:
# ln -sf /lib64/ld-linux.so.2 /lib/ld-linux.so.2
Old   February 24, 2011, 11:56
I removed i686.
I made ln command and the file was copied.
However i get the message
copying necessary files to /tmp/ans_install_tmp7323/
Executing /tmp/ans_install_tmp7323/instcore
/tmp/ans_install_tmp7323/INSTALL: /tmp/ans_install_tmp7323/instcore: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
How i make simlink?
Thank you for your time and effort!
Old   February 24, 2011, 12:09
Vadim
I removed i686.
How i make simlink?
Hmmm...
What`s a platform-version of your Ansys-package?
Old   February 24, 2011, 12:11
It is ANSYS13.0 for Linux 64.
I'm using Fedora 14 (64bit)
Old   February 24, 2011, 12:33
Vadim
So, that does mean you can solve the problem by making
symbolic link of /lib64/ld-linux-x86-64.so.2 to /lib64/ld-lsb-x86-64.so.3 and
second of /lib64/ld-lsb-x86-64.so.3 to /lib/ld-linux.so.*
There are no more troubles.
Old   February 25, 2011, 05:39
Default Thanks!
  #136
I installed fluent!
but now when i run fluent this problem occurs:
/usr/ansys_inc/v130/fluent/fluent13.0.0/lnamd64/3ddp/fluent.13.0.0: error while loading shared libraries: libiomp5.so: cannot enable executable stack as shared object requires: Permission denied
The fluent process could not be started.
Do you have any idea?
Old   February 26, 2011, 17:42
Default Ansys 13 and license manager
  #137
Phoevos
fivos is on a distinguished road
Hi to everyone,
I would like to share my experiences trying to use ansys 13 on linux (Ubuntu 64 8.10 to be more specific), since they might help others.
So on my ubuntu 8.10 x64 pc, I had already installed ansys 12 and set up the license server etc. Fluent and CFX components of ansys 12 worked as they should (serial & parallel) - since I am more concerned on CFD I only tried cfx and fluent, also I never liked workbench.
Today I decided to install ansys 13. Even if I tried the method described in page 5 of the current thread (I created the rpm and uname commands, commented out the second entry of MYHOSTNAME in etc/hosts, .....) I was still unable to connect to the license server, getting the same message as Siden (check at page 5 of current thread), namely :
couldn't execute "/ansys_inc/shared_files/licensing/linx64/lmutil": no such file or directory
I tried to execute lmutil from terminal to see what happens, but got the same response. Thinking that the lmutil might got corrupt somehow (?), I replaced it with the old lmutil from the old license manager of Ansys 12. Well now I was able to connect to the server, identify my license and start the licensing interconnect and the licensing interconnect monitor, the FlexLm however didn't start. Of course neither Fluent nor CFX started (12 or 13), giving me various responses from 'could not connect to license server' to 'segmentation fault' (!). Reverting to the old License manager solved the problems, but only for the old Fluent and CFX (12), the new ones requested the new version of the license manager.
So what I did was to replace the executables/files of the new license manager located at .../ansys_inc/shared_files/licensing/linx64 with the old executables/files of the Ansys 12 license manager apart from the ansyssli_server executable, which is neccessary for the new program versions to run. Well then all license manager components worked and, at last, both CFX and Fluent (12 and 13, including CFX pre, Solver and post) ran without errors, as long as I tried, serial and parallel !
I have tried to run workbench too using the script 'runwb2' at '/ansys_inc/v130/Framework/bin/Linux64/' but it didnt work, I got the following errors in terminal :
QPainter::setFont: Painter not active
QPixmap: It is not safe to use pixmaps outside the GUI thread
as already encountered by makkemal and Yankee (page 5 same thread). I have not tried the solution Yankee proposed, but I dont really care about workbench, I am happy fluent and cfx work.
To conclude I think that an important part of the trouble is the new license manager. My solution is rather cumbersome, since you need to mix the two license managers, but at least works for me.
fivos is offline   Reply With Quote
Old   February 28, 2011, 13:25
Default How to install ANSYS 13 on RHEL 6.0 x64 Workstation?
  #138
Karl Scmied
subway1958 is on a distinguished road
please, can you give me some help regarding this topic?
thanx in advance,
subway1958 is offline   Reply With Quote
Old   March 7, 2011, 12:30
ginggs is on a distinguished road
New flexlm tools are compiled for Linux Standard Base, if you don't have the lsb-core package installed you will see this error.
To fix:
sudo apt-get install lsb-core
ginggs is offline   Reply With Quote
Old   March 8, 2011, 05:20
Phoevos
To fix:
Thanks ginggs, I' ll keep that in mind for the next time.
LINUX Experts: Help with installing ANSYS workbench faisal_durr ANSYS 1 May 30, 2014 08:07
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 12:59
How can I start the ANSYS 12 workbench in LINUX Ardisia ANSYS 3 September 7, 2010 00:19
ANSYS Workbench on Linux CPUcruncher ANSYS 4 July 11, 2010 09:19
ANSYS Workbench on "Certified" linux distro mechanicaldesign CFX 0 April 16, 2010 01:56
